SQLite near error
dhaine_adp
Been thanked: 3 times
SQLite near error
Post by dhaine_adp »
Hello,
SQLite near error due to single quote "'" that contains in text streams (strings). Example:
Danny's Files
Côte d'Ivoire
French words, etc.
I modified the file sql1.prg from <c>:\hmg\samples\sql\sqlite that contains the function c2sql() as follows:
function C2SQL(Value)
   local cValue := ""
   local ii := 0  //--> added local variable
   local cTmp := ""   //--> added local variable
    local cFormatoDaData := set(4)
   do case
      case Valtype(Value) == "N"
         cValue := AllTrim(Str(Value))
      case Valtype(Value) == "D"
         if !Empty(Value)
            cdate := dtos(value)
            cValue := "'"+substr(cDate,1,4)+"-"+substr(cDate,5,2)+"-"+substr(cDate,7,2)+"'"
            cValue := "''"
      case Valtype(Value) $ "CM"
         IF Empty( Value)
            cValue="''"
            //-- fixed escaping single quote. Like Pascal Programming add an immediate "'"
            //-- to the single quote that precedes it. I have no choice but to use
            //-- brute force on this rather using rat() and at()
            for ii := 1 to len( value )
               if substr( value, ii, 1 ) == "'"
                  cTmp += substr( value, ii, 1 ) + "'"
            next
            value := cTmp
            cValue := "'" + value+ "'"
      case Valtype(Value) == "L"
         cValue := AllTrim(Str(iif(Value == .F., 0, 1)))
      otherwise
         cValue := "''"       // NOTE: Here we lose values we cannot convert
   endcase
The side effect is that it slows down the whole process most especially in batch mode. I have commented the lines that I've added (//--). If the variable "value" happens to be a memo, definitely it will be WWW (world wide wait) process.
Well it can be done from the calling function but by convention it must be processed from within the c2sql().
FYI.
Danny
Danny
Manila, Philippines
IMATECH
Has thanked: 9 times
Post by IMATECH »
Hi Dani !
You can replace all lines added by a single function ( same performance as ever ):
   value := "'" + StrTran( value, "'", "''" ) + "'"
I recomend you try hbdc class to work with sqLite ( Harbour Native, jdbc like for sqLite )
and for good practices ( SQL standards )
Database object names ( Column, Table and DB ) have to be enclosed with Brackets ( eg: [cFieldName] )
and char contents with single quotes ( eg: 'cData' )
M., Ronaldo
By: IMATECH
Imation Tecnologia
Has thanked: 411 times
Been thanked: 120 times
Hi Danny and Ronaldo,
Thanks to hints :)
Viva HMG :D
dhaine_adp
Hi Ronaldo,
Thanks for this:
Also thank you for suggesting "hbdc class". I think I'm gonna try this.
Danny
Danny
Manila, Philippines
dhaine_adp
Hi Ronaldo,
There are some still _TODO_ stuffs on the hbdc class. The code itself is neatly written but have you tried this in deployment/production code? Well I'm going to use SQLite database because I don't want some users to mess around with the tables by using MS-Excel to open its contents.
Also is there any tools or library to encrypt the contents of the SQLite database?
Danny
Danny
Manila, Philippines
Hi Danny
dhaine_adp wrote: Also is there any tools or library to encrypt the contents of the SQLite database?
Please look at :
viewtopic.php?f=35&t=2468&p=21656#p21656" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
and
viewtopic.php?f=9&t=2265&p=19555#p19555" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
May be found more; please use "Search" or "Advanced Search" of forum.
IMATECH
Post by IMATECH »
Hi Dani !
1 - hdbc _TODO_ stuffs are reserved for future implement...
But: since like most Relational DB, sqLite provides a unidirectional recordset
using hbbc, all we need to use is:
Connection
executeQuery
updateQuery
and to navigate on the recordset we use :next to retrieve data ( :getString, :getInteger... ) to any object...
2 - Yes, we use it in production :)
3 - SQLCipher is the best option to use with sqLite
4 - Test it and make your choice :)
M., Ronaldo
By: IMATECH
Imation Tecnologia
dhaine_adp
Hi Ronaldo,
Thanks for the tips. It works fine now. It took me 18 hours to migrate and test using hbdc including reading manual from the internet. I borrowed the code from the hmg sample as well. Here take a look at the code. It's my first code using SQL statement.
Esgici:
:lol: Thanks also for the links.
#include "minigui.ch"
#include "inkey.ch"
#include "common.ch"
#include "dale-aid.ch"
#require "hbsqlit3"
function sq3Makefile()
   LOCAL cMsg := ""
   LOCAL lRetVal := .f.
   LOCAL cCreateSQL := ""
   LOCAL cIndexSQL  := ""
   LOCAL cQstr      := ""
   LOCAL cID := ""
   LOCAL cNm := ""
   LOCAL cAR := ""
   LOCAL cLC, cCC, cST, cNT
   LOCAL oConn, oMeta, oStmt, cSql, oRS
   LOCAL aItems_ := {}
   BEGIN SEQUENCE
   IF .NOT. importOpen()
      BREAK
   oConn := hdbcSQLTConnection():New( sqDBLang, .T. )
   oMeta := oConn:getMetaData()
   cQstr := "SELECT * FROM sqlite_master WHERE type = 'table' ORDER BY name"
   **cQStr := "SELECT name, tbl_name FROM sqlite_master"
   oStmt := oConn:CreateStatement()
   **-- check sql database if tables are needed to be created
   oRS  := oStmt:executeQuery( cQstr )
   oRS:setTableName( "sqlite_master" )
   cNT := ""
   DO WHILE oRs:next()
      cNT := oRs:getString( "tbl_name" )
      IF .NOT. EMPTY( cNT )
         AADD( aItems_, cNT )
   ENDDO
   IF LEN( aItems_ ) > 0
      lRetVal := .t.
      oRs:Close()
      oStmt:Close()
      oConn:Close()
      BREAK
   oRs:Close()
   oStmt:Close()
   cNT := ""
   cCreateSQL := "CREATE TABLE country ("
   cCreateSQL += "  CCID char( 2 ) NOT NULL,"         // Country ID - Two-letter code from ISO-3166
   cCreateSQL += "  CCNM varchar( 75 ) NOT NULL,"     // Name - Country Name
   cCreateSQL += "  AREA varchar( 10 ) NOT NULL);"    // Area - World Area
   cCreateSQL += "CREATE TABLE LangCodes ("
   cCreateSQL += "  LANGID  char(3) NOT NULL,"       // -- Three-letter code iso-639-3
   cCreateSQL += "  COUNTRY char(2) NOT NULL,"       // -- Main country where used
   cCreateSQL += "  STATUS  char(1) NOT NULL,"       // -- L(iving), (e)X(tinct)
   cCreateSQL += "  NAME    varchar(75) NOT NULL);"  // -- Primary name in that country
   cCreateSQL += "CREATE TABLE LangIndex ("
   cCreateSQL += "  LANGID   char(3) NOT NULL,"       // -- Three-letter code for language iso-639-3
   cCreateSQL += "  COUNTRY  char(2) NOT NULL,"       // -- Country where this name is used
   cCreateSQL += "  NAMETYPE char(2) NOT NULL,"       // -- L(anguage), LA(lternate), D(ialect), DA(lternate), LP,DP (a pejorative alternate)
   cCreateSQL += "  NAME     varchar(75) NOT NULL)"   // -- The name
   cIndexSQL := "CREATE UNIQUE INDEX IdxCountry ON country (CCID,CCNM,AREA);"
   cIndexSQL += "CREATE INDEX LangC ON LangCodes (LANGID,COUNTRY,NAME);"
   cIndexSQL += "CREATE INDEX LangI ON LangIndex (LANGID,COUNTRY,NAME)"
   oStmt := oConn:createStatement()
   oStmt:executeUpdate( cCreateSQL )
   oStmt:executeUpdate( cIndexSQL )
   oStmt:Close()
   oConn:StartTransaction()
   DBSELECTAREA( "COUNTRY" )
   DBGOTOP()
   WHILE .NOT. EOF()
      cID := ALLTRIM( COUNTRY->CCID )
      cNM := ALLTRIM( COUNTRY->CCNM )
      cAR := ALLTRIM( COUNTRY->AREA )
      cNM := STRTRAN( cNM, "'", "''" )  // stuff extra single quote
      cQstr := "INSERT INTO country (CCID, CCNM, AREA) VALUES ( "
      cQstr +=  c2SQL( cID ) + ","
      cQstr +=  c2SQL( cNM ) + ","
      cQStr +=  c2SQL( cAR ) + ")"
      oStmt:executeUpdate( cQstr )
      DBSKIP()
   END
   oStmt:close()
   DBSELECTAREA( "WORLDLANG" )
   DBGOTOP()
   WHILE .NOT. EOF()
      cLC := ALLTRIM( WORLDLANG->LANGID )
      cCC := ALLTRIM( WORLDLANG->COUNTRY )
      cST := ALLTRIM( WORLDLANG->STATUS )
      cNM := ALLTRIM( WORLDLANG->NAME )
      cQstr := "INSERT INTO LangCodes (LANGID,COUNTRY,STATUS,NAME) VALUES ( "
      cQstr +=  c2SQL( cLC ) + ","
      cQstr +=  c2SQL( cCC ) + ","
      cQStr +=  c2SQL( cST ) + ","
      cQStr +=  c2SQL( cNM ) + ")"
      DBSKIP()
   END
   oStmt:close()
   DBSELECTAREA( "INDEXWORLD" )
   DBGOTOP()
   WHILE .NOT. EOF()
      cLC := ALLTRIM( INDEXWORLD->LANGID )
      cCC := ALLTRIM( INDEXWORLD->COUNTRY )
      cNT := ALLTRIM( INDEXWORLD->NAMETYPE )
      cNM := ALLTRIM( INDEXWORLD->NAME )
      cQstr := "INSERT INTO LangIndex (LANGID,COUNTRY,NAMETYPE,NAME) VALUES ( "
      cQStr +=  c2SQL( cNT ) + ","
      DBSKIP()
   END
   oStmt:close()
   oConn:Commit()
   oConn:Close()
   lRetVal := .t.
   MSGINFO( "Import to SQL is done.", "Finished" )
   END SEQUENCE
   IF .NOT. lRetVal
      MSGSTOP( cMsg, "Error" )
   DBCLOSEALL()
   RETURN lRetVal
static function importOpen()
   BEGIN SEQUENCE
   IF .NOT. NETUSE( ( dbCountry ), "COUNTRY", Shared, ReadOnly )
      cBreakMsg := "Cannot open file " + dbLangCC + "."
      BREAK
   ORDLISTADD( ( ixCountry ) )
   ORDSETFOCUS( "CountryID", ( ixCountry ) )
   IF .NOT. NETUSE( ( dbTLWorldLang ), "WORLDLANG", Shared, ReadOnly )
      cBreakMsg := "Cannot open file " + dbLangCd + "."
      BREAK
   ORDLISTADD( ( ixTLWorldLang ) )
   ORDSETFOCUS( "CountryID", ( ixTLWorldLang ) )
   IF .NOT. NETUSE( ( dbIndexWorld ), "INDEXWORLD", Shared, ReadOnly )
      cBreakMsg := "Cannot open file " + dbIndexWorld + "."
      BREAK
   ORDLISTADD( ( ixIndexWorld ) )
   ORDSETFOCUS( "LangArea", ( ixIndexWorld ) )
   lRetVal := .t.
   END ENSEQUENCE
   RETURN lRetVal
   local cValue := ""
   do case
         if !Empty(Value)
            cValue := "''"
         IF Empty( Value)
            cValue="''"
      otherwise
   endcase
return cValue
Danny
Danny
Manila, Philippines
IMATECH
Post by IMATECH »
Hi Dani !
Nice job :)
cQstr := "SELECT * FROM [sqlite_master] WHERE type = 'table' ORDER BY [sqlite_master].[name]"
cCreateSQL := "CREATE TABLE [country] ...
cQstr := "INSERT INTO [country] (CCID, CCNM, AREA) VALUES ( ... )
M., Ronaldo
By: IMATECH
Imation Tecnologia
