QTreeWidgetItem Icon
Has thanked: 249 times
Been thanked: 301 times
Hi
I invite your kind attention to Line no. 655 of QTreeWidgetItem.cpp file.
655 HB_FUNC( QT_QTREEWIDGETITEM_SETICON )
656 	{
657 	QTreeWidgetItem * p = hbqt_par_QTreeWidgetItem( 1 );
658 	if( p )
659 	( p )->setIcon( hb_parni( 2 ), QIcon( hbqt_par_QString( 3 ) ) );
660 	else
661 	{
662 	HB_TRACE( HB_TR_DEBUG, ( "............................... F=QT_QTREEWIDGETITEM_SETICON FP=( p )->setIcon( hb_parni( 2 ), QIcon( hbqt_par_QString( 3 ) ) ); p is NULL" ) );
663 	}
664 	}
It deals with setting an icon for tree items. As of now, the third parameter for this function should be a string (may be icon filename from disk or resource). In the case of tree item, we can have item states (normal and selected) (for example a closed book icon for normal state and an open book icon for selected state).
For this I have created a Quick Icon with two Pixmaps using addPixmap method.
Since the third parameter here is not QIcon but a string, I could not set the icon for treewidgetitem. I understand this is used for simplicity.
Now, can we have another function/method to pass the third parameter as QIcon itself?
bedipritpal
Post by bedipritpal »
rathinagiri wrote:Hi
Yep, thi slimitation is self induced one since very begining of hbQT evolution when I thought it is easier to send image by name rather than constructing icon before passing to another method. Your explanation above is valid and I am looking into how dynamically it can be resolved. A lot of code has already been developed around it, so I have to be extremely careful.
BTW: nothing personal, but can you change your Avatar to a simple image than blinking one. It just disturbs and probably need more patient to stay on the page it is depicted.
enjoy hbIDEing... Pritpal Bedi
