change abstractgrid.prg en no underline capture tab &
JosK
Post by JosK »
-i work with hmg.4 2011.11.23
- i will show my program.
- there is a bug in tabpage. i use o:capture :=&Rekscheman but the R is not underlined. If i do ctrl-r -> then the R is underlinend and the program goes to that tab
- jkgrid is a copy op visualgrid.
- i have change abstractgrid.prg. I hope you will copy it (and change it because i update all columns and that is not nessery).
You kan change columnwith but the screen was not updated .. see F7 key
METHOD ColumnWidths( aValue ) CLASS ABSTRACTGRID
LOCAL i
IF Pcount() == 0
RETURN ::aColumnWidths
ELSEIF Pcount() == 1 .AND. hb_Isarray( aValue )
::aColumnWidths := aValue
//ADD
IF ::lCreated
FOR i := 0 to len( aValue ) - 1
::oQTObject:setColumnWidth( i,aValue[i+1] )
NEXT i
This is my code sample:
#include "hbqtgui.ch"
#include "hbgtinfo.ch"
#include "std.ch"
SET DATE TO ANSI
SET EPOCH TO 1950 //KAN OOK CENTURY DOEN MAAR DAN 4 POSITIES..
SET CENTURY OFF
SET WRAP ON && ref 'menu to ...'
SET TALK OFF &&
SET BELL OFF &&
SET DELETED ON &&
SET SAFETY OFF &&
SET HEADING OFF &&
SET DELIMITERS OFF &&
SET SCOREBOARD OFF && geen Num, Ins, enz op lijn 0.
SET INTENSITY ON
SET DELIMITERS OFF
SET EXACT OFF
SET CURSOR OFF //KENT HMG NIET daar std.ch
SET DELETED ON && alleen btw bestand word direct gepackt ivm reccount()
SET EXCLUSIVE ON
setcancel(.f.)
FUNCTION Main()
//Public oTP1,oTP2
//Public oTLB //oTabpageLayoutBox -> local in oTP1
HbQt_ErrorSys()
wMain :=MaakMain("wMain")
oCW :=Widget():New("oCW",wMain)
oCW :CentralWidgetOF(wMain)
oLB :=LayoutBox():New("oLB",oCW,LAYOUT_TOPTOBOTTOM)
with object oTab:=Tab():New("oTab")
oTP1:=MaakTP1("oTP1",oTab)
oTP2:=MaakTP2("oTP2",oTab)
end
oTP1:caption:="T&abPage1"
oLB:add(oTab)
oLB:SetLayout()
ON KEY F10 OF WMAIN ACTION {|| MSGSTOP("f10 binnen wmain")}
ON KEY F8 OF WMAIN ACTION {|| MSGSTOP( str( oTP1.oTLB:direction()))}
//0=l->r, 1=r-l, 2=t-b, 3=b-t, 4=form, 5=grid
ON KEY F9 OF WMAIN ACTION {|| if( (x:=oTP1.oTLB:Direction()) ==3, oTP1.oTLB:Directon(0), oTP1.oTLB:Direction(x+1) )}
//F9 heeft geen invloed op child olF onder oTLB
ON KEY F7 OF WMAIN ACTION {|| x:=oTP2.oBrowse:ColumnWidths(),x[2]:=800,oTP2.oBrowse:ColumnWidths(x),oTP2.oBrowse:Refresh() }
ON KEY F6 OF WMAIN ACTION {|| x:=oTP2.oBrowse:ColumnHeaders(),x[2]:="TEST",oTP2.oBrowse:ColumnHeaders(x),oBrowse:Refresh() }
wMain:Activate()
Return NIL
STATIC FUNCTION MaakMain(c)
static o
if o==nil
o:= MAINWINDOW():New(c)
o:Title := "Maak Main Demo"
return o
STATIC FUNCTION MaakTab(c,oParent,nRow)
local o
o:=Tab():New(c,oParent)
return o
FUNCTION MaakTP1(c,oParent)
local oTLB,oBrowse
static o
if o=Nil
//indien meerdere items op horizontaal is apart frame
// auto van 1/2 lines gaat niet lukken naar groot/klein scherm
o:=TabPage():New(c,oParent)
o:caption:="&Tabpage1" //T niet onderlijnd de 1e keer
oTLB:=LayoutBox():New("oTLB",o)
oTLB:direction(2) //t-b
oBrowse:=MaakBrowse("oBrowse",o)
oLF:=Layoutform():New("oLF",oTLB)
oB1:=Button():New()
oB1:caption("Button1")
oT1:=TextBox():New()
oB2:=Button():New()
oB3:=MaakBtn("oB3")
oLF:add(oB1)
oLF:add(oT1)
oLF:add(oB2)
oLF:add(oB3)
oTLB:addlayout(oLF)
oTLB:add(oBrowse)
oTLB:stretch(1,20)
oTLB:stretch(2,80)
oTLB:setlayout()
return o
STATIC FUNCTION MaakBtn(c,oParent)
static o
o:=Button():New(c,oParent)
o:MaxWidth :=300
o:Caption := "Current Language"
o:OnClick := { || Bt1_OnClick() }
RETURN o
STATIC FUNCTION Bt1_OnClick()
MsgInfo( "Current Language is " + hb_ValToExp( HMGAPP():Language() ), "Language" )
FUNCTION MaakTP2(c,oParent)
local oTLB,oBrowse
static o
//go top
if o=Nil
o:caption:="&RekSchema"
oTLB:=LayoutBox():New("oTLB",o,LAYOUT_TOPTOBOTTOM)
oTLB:add(oBrowse)
oTLB:setlayout()
return o
function MaakBrowse(c,oParent)
static o
static bColor := { || IF ( ordkeyno()/2 == INT(ordkeyno()/2) , { 222,222,222 } , { 255,255,255 } ) }
static fColor := { || IF ( ordkeyno()/2 == INT(ordkeyno()/2) , { 255,0,0 } , { 0,0,255 } ) }
use c:\hmg.4\svn\samples\t\demo alias demo
//o:=jkGrid():New(c,oParent)
o:Row := 10
o:Col := 10
o:Width := 690
o:Height := 615
o:WorkArea := 'demo'
//o:OnChange :={||MsgInfo( "Andere cell/regel geselecteerd!" )}
//o:ONDBLClick :={||MsgInfo( "We gaan cell editten!" )}
* 'First','Last','Street','City','State','Zip','Hire Date','Married' ,'Age', Salary' , 'Notes'}
* '1,2,3,4,5,6Zip,7H,8'Married',9Age',10Salary' , 11Notes'}
//kreeg een error er daarom columnHeader toegevoegd
o:ColumnHeaders := { 'First' , 'Last' , 'Street' , 'City' , 'State' , 'Zip' , 'HireDate' , 'Married' , 'Age' , 'Salary' , 'Notes' }
o:ColumnFields := { 'First' , 'Last' , 'Street' , 'City' , 'State' , 'Zip' , 'HireDate' , 'Married' , 'Age' , 'Salary' , 'Notes' }
o:ColumnWidths := { 150 , 150 , 150 , 150 , 150 , 150 , 150 , 150 , 150 , 150 , 150 }
// ColumnJustify {GRID_JTFY_LEFT,GRID_JTFY_RIGHT,GRID_JTFY_LEFT,GRID_JTFY_LEFT,GRID_JTFY_LEFT,GRID_JTFY_RIGHT,GRID_JTFY_LEFT}
// brw_left etc is idem als grid_jtfy_left
o:ColumnJustify := { BRW_LEFT , BRW_RIGHT , BRW_CENTER , BRW_LEFT , BRW_RIGHT , BRW_CENTER , BRW_LEFT , BRW_RIGHT , BRW_CENTER , BRW_LEFT , BRW_RIGHT }
o:DynamicBackColor := { bColor , bColor , bColor , bColor , bColor , bColor , bColor , bColor , bColor , bColor , bColor }
o:DynamicForeColor := { fColor , fColor , fColor , fColor , fColor , fColor , fColor , fColor , fColor , fColor , fColor }
o:DynamicDisplay := { { || UPPER(First) } , NIL , NIL , NIL , NIL , NIL , NIL , { || IF(married,'Married','Not Married' ) } , NIL , NIL , NIL }
o:OnHeadClick := { { || MsgInfo( 'Click 1' ) } , , { || MsgInfo( 'Click 3' ) } , { || MsgInfo( 'Click 4' ) } , { || MsgInfo( 'Click 5' ) } , { || MsgInfo( 'Click 6' ) } , { || MsgInfo( 'Click 7' ) } , { || MsgInfo( '8' ) } , ,}
o:HeaderImages := { 'new.png' , 'open.png' , 'paste.png' , 'save.png' , 'new.png' , 'open.png' , 'paste.png' , 'save.png' , 'new.png' , 'open.png' , 'paste.png' }
o:lVScrollBar := .f.
//1.1= textbox,checkbox
//1.2=nummeric,date,character
//1.3=imputmask
//1.4=format alleen bij nummeric
// justify via andere array
//1="checkbox", caption=2of3,onchange=2of3 hij checkt op wel/niet block!?
//1="datepicker",2="UPDOWN" else updown=f
//1="spinner",2=RangeMin, 3=RangeMax
//1="combobox",2=items=array
o:ColumnControls :={{'TEXTBOX','CHARACTER'},;
{'TEXTBOX','CHARACTER','@K'},;
{"SPINNER",1,1000},;
{"COMBOBOX",{"January","February","March","April","May","June","July","August","September","October","November","December"}},;
{'TEXTBOX','CHARACTER',"@K"},;
{"DATEPICKER","UpDown"},;
{'CHECKBOX','Yes','No'},;
{'TEXTBOX','NUMERIC','99'},;
{'TEXTBOX','NUMERIC','999.99'},;
{'TEXTBOX','CHARACTER'};
o:MultiSelect := .F. //bij true = geen edit , alleen display
o:AllowEdit := .T. //alleen indien columnControls is ingevuld
o:Lines := .F.
o:VScrollBar := .F.
o:ColumnWhen := { { || UPPER(LEFT(first,1) ) == 'A' } ,;
//msgstop wordt bij opbouwen scherm bij iedere regel getoond
//bij when en browse problem want werd bij iedere regel werd when uitgevoerd; ook bij opbouwen scherm
//er moet een block in staan want anders error na intoetsen key
//o:ColumnWhen := { { || UPPER(LEFT(first,1) ) == 'A' } , , , , , , , , , , }
//o:ColumnValid := { { || !EMPTY(memvar.demo.first) } , , , , , , , , , { || demo->salary > 100 } , }
o:ColumnValid := { { || !EMPTY(demo.first) } , , , , , , , , , { || demo->salary > 100 } , }
o:ValidMessages := { "First name can't be EMPTY" , , , , , , , , , "Salary mus be greater than 100" , }
x1:=len(o:ColumnControls())
x2:=len(o:ColumnValid())
x3:=len(o:ValidMessages())
if x1#x2.or.x1#x3
msgstop("x1="+str(x1) + " x2="+str(x2)+ " x3="+str(x3))
return o
JosK
Post by JosK »
also a bug with o:VScrollBar:=.f. ?
no HScrollBar ?
JosK
Post by JosK »
old (but newer than 23/11/2011):
LOCAL i
IF Pcount() == 0
//ADD
IF ::lCreated
NEXT i
new:
LOCAL i
IF Pcount() == 0
IF !::lCreated
IF aValue[i+1] # ::aColumnWidths[i+1]
::aColumnWidths[i+1]:=aValue[i+1]
NEXT i
but new doesn't work!
this is because ::lCreated is not set after the first time ?
i also have two bugs that i cannot find
1. look at on key F9. i get an error if Direction(0)
2. tabpage caption &Tabpage en &Rek is not underline the first time. If i do Alt-T then it shows.
Here is my source, look at on key F7 for the ColumnWidths
#include "std.ch"
SET DATE TO ANSI
SET CENTURY OFF
SET TALK OFF &&
SET BELL OFF &&
SET DELETED ON &&
SET SAFETY OFF &&
SET HEADING OFF &&
SET INTENSITY ON
SET DELIMITERS OFF
SET EXACT OFF
SET EXCLUSIVE ON
setcancel(.f.)
FUNCTION Main()
//Public oTP1,oTP2
HbQt_ErrorSys()
end
oLB:add(oTab)
oLB:SetLayout()
ON KEY F6 OF WMAIN ACTION {|| x:=oTP2.oBrowse:ColumnHeaders(),x[2]:="TEST",oTP2.oBrowse:ColumnHeaders(x),oTP2.oBrowse:Refresh() }
ON KEY F5 OF WMAIN ACTION {|| x:=oTP1.oBrowse:ColumnJustify(),x[4]:=BRW_RIGHT,oTP1.oBrowse:ColumnJustify(x),oTP1.oBrowse:Refresh() }
//o:ColumnJustify := { BRW_LEFT , BRW_RIGHT , BRW_CENTER , BRW_LEFT , BRW_RIGHT , BRW_CENTER , BRW_LEFT , BRW_RIGHT , BRW_CENTER , BRW_LEFT , BRW_RIGHT }
wMain:Activate()
Return NIL
static o
if o==nil
return o
local o
return o
local oTLB,oBrowse,oTB
static o
if o=Nil
oTB:=maakToolBar("oTB",o)
oB1:=Button():New()
oB2:=Button():New()
oB3:=MaakBtn("oB3")
oLF:add(oB1)
oLF:add(oT1)
oLF:add(oB2)
oLF:add(oB3)
oTLB:addlayout(oLF)
oTLB:add(oBrowse)
oTLB:add(oTB)
oTLB:stretch(1,20)
oTLB:stretch(2,80)
oTLB:setlayout()
return o
static o
o:MaxWidth :=300
RETURN o
local oTLB,oBrowse
static o
//go top
if o=Nil
oTLB:add(oBrowse)
oTLB:setlayout()
return o
static o
o:Row := 10
o:Col := 10
o:Width := 690
o:Height := 615
//1.3=imputmask
o:Lines := .F.
o:VScrollBar := .F.
if x1#x2.or.x1#x3
return o
function maakToolBar(c,oParent)
static o
if o==NIL
o:=Toolbar():New(c,oParent)
* via methode atObject:addToolBar en oParent=Tab heeft deze niet.
* opgelost via aanpassen toolbar.prg in methode new del addtoolbar
o:MOVEABLE := .F.
//oTB:TBARPLACE:= Qt_RightToolBarArea
with Object TOOLBUTTON():New("TB1",o)
:Caption := "Save"
:Picture := "save.png"
:OnClick := {|| MsgInfo( "Save!" )}
:ToolTip := "ToolTip"
end
with Object TOOLBUTTON():New("TB2",o)
:Caption := "Save"
end
end
return o
mrduck
Post by mrduck »
JosK wrote:i have change abstractgrid.prg
JosK, qas I said I will look at your code from tomorrow (I'm travelling today).
In the meanwhile I ask you to modify your message and put around your code the tag to let the forum software that it is source code.
You should add
[ code ]
source code...
[ /code ]
WITHOUT SPACES to achieve the following (that respects spaces and it is more easy to cut/paste):
   source code...
Thanks
