Set properties
Has thanked: 249 times
Been thanked: 301 times
Set properties
Today I had downloaded the new version from SVN.
The editbox.prg contains the following lines:
	* Set Properties
	if ValType (::cValue)		!= 'U'	; Self:Value		:= ::cValue		; EndIf
	if ValType (::Row)		!= 'U'	; Self:Row		:= ::nRow		; EndIf
	if ValType (::Col)		!= 'U'	; Self:Col		:= ::nCol		; EndIf
	if ValType (::Width)		!= 'U'	; Self:Width		:= ::nWidth		; EndIf
	if ValType (::Height)		!= 'U'	; Self:Height		:= ::nHeight		; EndIf
	if ValType (::ScrollBars)	!= 'U'	; Self:ScrollBars	:= ::nScrollBars	; EndIf
	if ValType (::cFontName)	!= 'U'	; Self:FontName		:= ::cFontName 		; EndIf
	if ValType (::nFontSize)	!= 'U'	; Self:FontSize		:= ::nFontSize 		; EndIf
	if ValType (::lBold)		!= 'U'	; Self:FontBold		:= ::lBold 		; EndIf
	if ValType (::lItalic)		!= 'U'	; Self:FontItalic	:= ::lItalic 		; EndIf
	if ValType (::lUnderline)	!= 'U'	; Self:FontUnderline	:= ::lUnderline 	; EndIf
	if ValType (::lStrikeout)	!= 'U'	; Self:FontStrikeOut	:= ::lStrikeout 	; EndIf
	if ValType (::cToolTip)		!= 'U'	; Self:ToolTip		:= ::cToolTip		; EndIf
	if ValType (::lReadOnly)	!= 'U'	; Self:ReadOnly		:= ::lReadOnly		; EndIf
	if ValType (::lTabStop)		!= 'U'	; Self:TabStop		:= ::lTabStop		; EndIf
	if ValType (::bOnGotFocus)	!= 'U'	; Self:OnGotFocus	:= ::bOnGotFocus	; endif
	if ValType (::bOnLostFocus)	!= 'U'	; Self:OnLostFocus	:= ::bOnLostFocus	; endif
I wish to extend this to checkbox control, on which I am working on.
And, please consider these lines
In the first line ::Row is verified for 'U' where as in the next line ::cFontName is verified. I want to know whether it is ::cFontName or ::FontName (like the previous line)
However, Self:Row and Self:FontName are the same for both the lines. Am I missing something here?! or I don't understand something basic?
Please help me out.
Has thanked: 5 times
Been thanked: 4 times
Hello Rathi,
In my very humble opinion it will be ::cFontName
May be I am wrong, but I think
::oObject:FontName
or
oObject:FontName
and
::cFontName
I don't know OOP very much. So, please correct me if I am wrong.
Now, there are two things inherited from the parent class (ie., control)
DATA are defined with the proper notation. (ie., adding c,n,l,a wherever necessary).
METHOD is defined with their name (like Value, Row, Col etc., to set/get the properties.
IMHO, these lines are someway or other, linking these data to these methods at the time of initialization.
I think Roberto can explain easily!
Has thanked: 85 times
Been thanked: 184 times
rathinagiri wrote: I wish to extend this to checkbox control, on which I am working on.
Please help me out.
Instead:
if ValType (::Row)
It must be:
if ValType (::nRow)
When the instance variable was initializated (!=Nil) we must to call the method required.
For ::nRow, the method is Self:Row.
Please, let me know if I've was clear enough (I've got a cold and I have fever, so maybe my explanation be not good as it should be:) )
Yes, of course.
Thanks for the explanation Roberto.
So, that means, we have to change in the editbox.prg too!
rathinagiri wrote:Thanks for the explanation Roberto.
Yes... all other should be changed...
