MySQL Connection bug
Gochito
Post by Gochito »
I'm depeloping a project using MySQL as database.
When the next line sets the connection with the MySQL server, there is an error
oServidor := TMySQLServer():New(cServidor, cUsuario, cPassword)
This is the bug report:
When Date:11-08-2009 Time: 09:19:55
Error BASE/1004 No exported method: ADDMULTIDATA
Called from HBCLASS:ADDMULTIDATA(0)
Called from TMYSQLSERVER(1393)
Now, when I delete from my proyect a little code that lets the user to change the application date, the proyect compiles without problems. If I compile the full project with an old version, I have no problems.
Has thanked: 251 times
Been thanked: 302 times
It seems correct. Which HMG version are you using?
