alternative to msgbox, msgstop
l3whmg
Been thanked: 1 time
Post by l3whmg »
Hello to everyone.
I wish to share with you a simple evolution and emulation of functions “msgBox”, “msgStop”, etc...
I tried an alternative. A little exercise and to expand the capabilities of these functions: so I made this simple library.
I hope it will be useful to someone or use it as an example of MiniGui.
Within the compressed file, you will find: the library, a sample source and the images needed (which of course you can change, as other options).
Are appreciated suggestions for its improvement as well as review :mrgreen: .
Regards.
LikeMsg.zip
source and example
(146.6 KiB) Downloaded 677 times
Luigi from Italy
www.L3W.it
Vanguarda
Post by Vanguarda »
Hi friends,
Hi friend Luigi.
Thanks for sharing this nice function with us.
My best regards,
claudiotedesco
Post by claudiotedesco »
Hola Regards
Te queria preguntar porque me da error la compilacion?
te paso el codigo de error
Gracias
Claudio
hbmk2: Processing configuration: e:\hmg\harbour\bin\hbmk.cfg
hbmk2: Processing: test.hbc
hbmk2: Compiling Harbour sources...
Harbour 2.0.0 (Rev. 13372)
Copyright (c) 1999-2010, http://www.harbour-project.org/
E:/hmg/ejeLikeMsg/l3w_msgout.prg(189) Error E0030 Syntax error "syntax error at '_CMESSAGE'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(190) Error E0030 Syntax error "syntax error at '_CTITLE'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(191) Error E0030 Syntax error "syntax error at '_NTYPE'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(192) Error E0030 Syntax error "syntax error at '_NSIGNAL'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(193) Error E0030 Syntax error "syntax error at '_LSOUND'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(194) Error E0030 Syntax error "syntax error at '_LREVERT'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(258) Error E0030 Syntax error "syntax error at 'WINDOW'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(260) Error E0030 Syntax error "syntax error at 'WIN0_SIGN'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(261) Error E0020 Incomplete statement or unbalanced delimiters
E:/hmg/ejeLikeMsg/l3w_msgout.prg(271) Error E0030 Syntax error "syntax error at 'EDITBOX'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(272) Error E0030 Syntax error "syntax error at 'L3WIN0'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(273) Error E0030 Syntax error "syntax error at '_OSELF'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(274) Error E0030 Syntax error "syntax error at '_OSELF'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(275) Error E0030 Syntax error "syntax error at '_OSELF'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(276) Error E0030 Syntax error "syntax error at '_OSELF'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(277) Error E0030 Syntax error "syntax error at '_OSELF'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(278) Error E0030 Syntax error "syntax error at '_OSELF'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(279) Error E0030 Syntax error "syntax error at '.F.'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(280) Error E0030 Syntax error "syntax error at '.T.'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(281) Error E0030 Syntax error "syntax error at ''"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(282) Error E0030 Syntax error "syntax error at '.T.'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(283) Error E0030 Syntax error "syntax error at '.T.'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(284) Error E0030 Syntax error "syntax error at '.F.'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(285) Error E0030 Syntax error "syntax error at 'END'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(288) Error E0030 Syntax error "syntax error at 'BUTTON'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(289) Error E0030 Syntax error "syntax error at 'L3WIN0'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(290) Error E0030 Syntax error "syntax error at '_OSELF'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(291) Error E0030 Syntax error "syntax error at '_OSELF'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(292) Error E0030 Syntax error "syntax error at 'Ok'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(293) Error E0030 Syntax error "syntax error at '_OSELF'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(294) Error E0030 Syntax error "syntax error at '_OSELF'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(295) Error E0030 Syntax error "syntax error at '_OSELF'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(296) Error E0030 Syntax error "syntax error at '_OSELF'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(297) Error E0030 Syntax error "syntax error at '_OSELF'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(298) Error E0030 Syntax error "syntax error at '.T.'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(299) Error E0030 Syntax error "syntax error at '.T.'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(300) Error E0030 Syntax error "syntax error at '.F.'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(301) Error E0030 Syntax error "syntax error at 'END'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(303) Error E0030 Syntax error "syntax error at 'BUTTON'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(304) Error E0030 Syntax error "syntax error at 'L3WIN0'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(305) Error E0030 Syntax error "syntax error at '_OSELF'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(306) Error E0030 Syntax error "syntax error at '_OSELF'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(307) Error E0030 Syntax error "syntax error at 'Cancel'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(308) Error E0030 Syntax error "syntax error at '_OSELF'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(309) Error E0030 Syntax error "syntax error at '_OSELF'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(310) Error E0030 Syntax error "syntax error at '_OSELF'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(311) Error E0030 Syntax error "syntax error at '_OSELF'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(312) Error E0030 Syntax error "syntax error at '_OSELF'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(313) Error E0030 Syntax error "syntax error at '.T.'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(314) Error E0030 Syntax error "syntax error at '.T.'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(315) Error E0030 Syntax error "syntax error at '.F.'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(316) Error E0030 Syntax error "syntax error at 'END'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(318) Error E0030 Syntax error "syntax error at 'BUTTON'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(319) Error E0030 Syntax error "syntax error at 'L3WIN0'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(320) Error E0030 Syntax error "syntax error at '_OSELF'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(321) Error E0030 Syntax error "syntax error at '_OSELF'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(322) Error E0030 Syntax error "syntax error at 'Abort'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(323) Error E0030 Syntax error "syntax error at '_OSELF'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(324) Error E0030 Syntax error "syntax error at '_OSELF'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(325) Error E0030 Syntax error "syntax error at '_OSELF'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(326) Error E0030 Syntax error "syntax error at '_OSELF'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(327) Error E0030 Syntax error "syntax error at '_OSELF'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(328) Error E0030 Syntax error "syntax error at '.T.'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(329) Error E0030 Syntax error "syntax error at '.T.'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(330) Error E0030 Syntax error "syntax error at '.F.'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(331) Error E0030 Syntax error "syntax error at 'END'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(333) Error E0030 Syntax error "syntax error at 'BUTTON'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(334) Error E0030 Syntax error "syntax error at 'L3WIN0'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(335) Error E0030 Syntax error "syntax error at '_OSELF'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(336) Error E0030 Syntax error "syntax error at '_OSELF'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(337) Error E0030 Syntax error "syntax error at 'Retry'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(338) Error E0030 Syntax error "syntax error at '_OSELF'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(339) Error E0030 Syntax error "syntax error at '_OSELF'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(340) Error E0030 Syntax error "syntax error at '_OSELF'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(341) Error E0030 Syntax error "syntax error at '_OSELF'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(342) Error E0030 Syntax error "syntax error at '_OSELF'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(343) Error E0030 Syntax error "syntax error at '.T.'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(344) Error E0030 Syntax error "syntax error at '.T.'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(345) Error E0030 Syntax error "syntax error at '.F.'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(346) Error E0030 Syntax error "syntax error at 'END'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(348) Error E0030 Syntax error "syntax error at 'BUTTON'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(349) Error E0030 Syntax error "syntax error at 'L3WIN0'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(350) Error E0030 Syntax error "syntax error at '_OSELF'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(351) Error E0030 Syntax error "syntax error at '_OSELF'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(352) Error E0030 Syntax error "syntax error at 'Ignore'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(353) Error E0030 Syntax error "syntax error at '_OSELF'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(354) Error E0030 Syntax error "syntax error at '_OSELF'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(355) Error E0030 Syntax error "syntax error at '_OSELF'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(356) Error E0030 Syntax error "syntax error at '_OSELF'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(357) Error E0030 Syntax error "syntax error at '_OSELF'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(358) Error E0030 Syntax error "syntax error at '.T.'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(359) Error E0030 Syntax error "syntax error at '.T.'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(360) Error E0030 Syntax error "syntax error at '.F.'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(361) Error E0030 Syntax error "syntax error at 'END'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(363) Error E0030 Syntax error "syntax error at 'BUTTON'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(364) Error E0030 Syntax error "syntax error at 'L3WIN0'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(365) Error E0030 Syntax error "syntax error at '_OSELF'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(366) Error E0030 Syntax error "syntax error at '_OSELF'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(367) Error E0030 Syntax error "syntax error at 'Yes'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(368) Error E0030 Syntax error "syntax error at '_OSELF'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(369) Error E0030 Syntax error "syntax error at '_OSELF'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(370) Error E0030 Syntax error "syntax error at '_OSELF'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(371) Error E0030 Syntax error "syntax error at '_OSELF'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(372) Error E0030 Syntax error "syntax error at '_OSELF'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(373) Error E0030 Syntax error "syntax error at '.T.'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(374) Error E0030 Syntax error "syntax error at '.T.'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(375) Error E0030 Syntax error "syntax error at '.F.'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(376) Error E0030 Syntax error "syntax error at 'END'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(378) Error E0030 Syntax error "syntax error at 'BUTTON'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(379) Error E0030 Syntax error "syntax error at 'L3WIN0'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(380) Error E0030 Syntax error "syntax error at '_OSELF'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(381) Error E0030 Syntax error "syntax error at '_OSELF'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(382) Error E0030 Syntax error "syntax error at 'No'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(383) Error E0030 Syntax error "syntax error at '_OSELF'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(384) Error E0030 Syntax error "syntax error at '_OSELF'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(385) Error E0030 Syntax error "syntax error at '_OSELF'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(386) Error E0030 Syntax error "syntax error at '_OSELF'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(387) Error E0030 Syntax error "syntax error at '_OSELF'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(388) Error E0030 Syntax error "syntax error at '.T.'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(389) Error E0030 Syntax error "syntax error at '.T.'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(390) Error E0030 Syntax error "syntax error at '.F.'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(391) Error E0030 Syntax error "syntax error at 'END'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(393) Error E0030 Syntax error "syntax error at 'BUTTON'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(394) Error E0030 Syntax error "syntax error at 'L3WIN0'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(395) Error E0030 Syntax error "syntax error at '_OSELF'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(396) Error E0030 Syntax error "syntax error at '_OSELF'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(397) Error E0030 Syntax error "syntax error at 'Try'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(398) Error E0030 Syntax error "syntax error at '_OSELF'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(399) Error E0030 Syntax error "syntax error at '_OSELF'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(400) Error E0030 Syntax error "syntax error at '_OSELF'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(401) Error E0030 Syntax error "syntax error at '_OSELF'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(402) Error E0030 Syntax error "syntax error at '_OSELF'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(403) Error E0030 Syntax error "syntax error at '.T.'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(404) Error E0030 Syntax error "syntax error at '.T.'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(405) Error E0030 Syntax error "syntax error at '.F.'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(406) Error E0030 Syntax error "syntax error at 'END'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(408) Error E0030 Syntax error "syntax error at 'BUTTON'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(409) Error E0030 Syntax error "syntax error at 'L3WIN0'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(410) Error E0030 Syntax error "syntax error at '_OSELF'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(411) Error E0030 Syntax error "syntax error at '_OSELF'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(412) Error E0030 Syntax error "syntax error at 'Continue'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(413) Error E0030 Syntax error "syntax error at '_OSELF'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(414) Error E0030 Syntax error "syntax error at '_OSELF'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(415) Error E0030 Syntax error "syntax error at '_OSELF'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(416) Error E0030 Syntax error "syntax error at '_OSELF'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(417) Error E0030 Syntax error "syntax error at '_OSELF'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(418) Error E0030 Syntax error "syntax error at '.T.'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(419) Error E0030 Syntax error "syntax error at '.T.'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(420) Error E0030 Syntax error "syntax error at '.F.'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(421) Error E0030 Syntax error "syntax error at 'END'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(423) Error E0030 Syntax error "syntax error at 'END'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(428) Error E0030 Syntax error "syntax error at 'WINDOW'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(429) Error E0030 Syntax error "syntax error at 'WINDOW'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(430) Error E0010 ENDIF does not match IF
E:/hmg/ejeLikeMsg/l3w_msgout.prg(441) Error E0030 Syntax error "syntax error at 'WAVE'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(443) Error E0030 Syntax error "syntax error at 'WAVE'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(445) Error E0030 Syntax error "syntax error at 'WAVE'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(447) Error E0030 Syntax error "syntax error at 'WAVE'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(449) Error E0030 Syntax error "syntax error at 'WAVE'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(461) Error E0030 Syntax error "syntax error at '.'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(462) Error E0030 Syntax error "syntax error at '.'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(464) Error E0030 Syntax error "syntax error at '.'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(465) Error E0030 Syntax error "syntax error at '.'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(467) Error E0030 Syntax error "syntax error at '.'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(468) Error E0030 Syntax error "syntax error at '.'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(470) Error E0030 Syntax error "syntax error at '.'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(471) Error E0030 Syntax error "syntax error at '.'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(473) Error E0030 Syntax error "syntax error at '.'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(490) Error E0030 Syntax error "syntax error at '.'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(492) Error E0030 Syntax error "syntax error at '.'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(501) Error E0030 Syntax error "syntax error at '.'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(503) Error E0030 Syntax error "syntax error at '.'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(510) Error E0030 Syntax error "syntax error at '.'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(512) Error E0030 Syntax error "syntax error at '.'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(519) Error E0030 Syntax error "syntax error at '.'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(521) Error E0030 Syntax error "syntax error at '.'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(530) Error E0030 Syntax error "syntax error at '.'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(532) Error E0030 Syntax error "syntax error at '.'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(541) Error E0030 Syntax error "syntax error at '.'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(543) Error E0030 Syntax error "syntax error at '.'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(550) Error E0030 Syntax error "syntax error at '.'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(552) Error E0030 Syntax error "syntax error at '.'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(557) Error E0030 Syntax error "syntax error at '.'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(575) Error E0030 Syntax error "syntax error at '.'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(584) Error E0030 Syntax error "syntax error at '.'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(593) Error E0030 Syntax error "syntax error at '.'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(602) Error E0030 Syntax error "syntax error at '.'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(611) Error E0030 Syntax error "syntax error at '.'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(620) Error E0030 Syntax error "syntax error at '.'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(629) Error E0030 Syntax error "syntax error at '.'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(638) Error E0030 Syntax error "syntax error at '.'"
E:/hmg/ejeLikeMsg/l3w_msgout.prg(647) Error E0030 Syntax error "syntax error at '.'"
192 errors
No code generated.
hbmk2: Error: Running Harbour compiler (embedded). 1
(e:\hmg\harbour\bin\harbour.exe) -n2 E:/hmg/ejeLikeMsg/l3w_msgout.prg /q -o.hbmk\win\mingw\ -ie:/hmg/harbour/include -ie:/hmg//include -iE:/hmg/ejeLikeMsg -iE:/hmg/ejeLikeMsg/
l3whmg
Post by l3whmg »
Hi Claudio,
I'm not a Guru, I'm a Newbe :mrgreen: but...
Do you have compiled ONLY "l3w_msgout.prg" or "test.prg"? Because "l3w_msgout.prg" it's intended like a library, a function. In fact, on the top of "test.prg" there are some include file.
To compile I'm using my review (but with little more differences) of "build.bat" command (distribuited with Minigui) without this error: can you post your compile command in a zip file? I will try.
The first error, line 189, about
DEFAULT _cMessage := "Undefined message"
, perhaps it's my mystake, but I've not received error during compilation; I investigate about this syntax!
I am at your disposal, best regard
Luigi from Italy
www.L3W.it
l3whmg
Post by l3whmg »
Ciao Claudio,
about the error at line 189 (and for this reason I think you don't have compiled with all include files), the syntax
DEFAULT varname := value
is a "translation" command; you can find the corresponding translation, in MiniGui include file "i_graph.ch":
#xcommand DEFAULT <uvar1> := <uVal1>;...
It's useful (for me) to set a default value (in a function) if a parameter it's not passed.
Your report has been helpful to me. I will add the transcoding of the command in my include file.
Luigi from Italy
www.L3W.it
