IDE UPDATE (XIIb)
- HMG Founder
IDE UPDATE (XIIb)
This update features a new experimental errorlog window.
You can now navigate the error messages, see and edit involved source code and then rebuild the project from the same place.
The messages are 'hard-coded' in English.
Enjoy!
Enjoy!
- ide_30_test_12b.rar
- (820.88 KiB) Downloaded 415 times
Re: IDE UPDATE (XIIb)
Hello Master Roberto,Roberto Lopez wrote: This update features a new experimental errorlog window.
Enjoy!
Thanks a lot. I am using it
Thank you again for this excellent feature
Oh! Thanks a lot Roberto.
- HMG Founder
A post from you inspired me to do thatsudip wrote: Hello Master Roberto,
Thanks a lot. I am using it(and just now it saved lots of my time and energy
) It is very very helpful to me
Thank you again for this excellent feature![]()
Hi friends,
Thanks Master for this nice feature.
PS: Friends, i think that i´m on bad luck epoch. Last Sunday lightning burned my computers and my modem.
Hence i´m still off-line.
I hope solve this problem soon. But my provider of Internet are much slow for apply the replace of my modem. Besides that, i´ll buy another computer for me.
I hope you will forgive me my time off-line, but once you solve these problems I'm going back to being online all day as usual.
My best regards,
My best regards,
Maestro en el ide si tenemos un control y por error damos el click en el nombre del evento sale un error
Error BASE/1003 Variable does no exist : RESULT
este error no sale si se de en value , + , - , solamente como ya dije si damos en el nombre del evento.
I know this IDE has potential since I had wrote a few small programs already with the 2.94 IDE. I am having a problem though with HMG-IDE 3.0. Has anyone had an HMG-IDE error:
c:\hmg\BUILD.BAT Not Found!
Mike
Mike
- HMG-IDE30-error.gif (13.58 KiB) Viewed 6418 times
_________________
Sincerely,
Mike
Sincerely,
Mike
- HMG Founder
Could you be so kind to give some details about the problem?martingz wrote:Maestro en el ide si tenemos un control y por error damos el click en el nombre del evento sale un error
I just can reprodice the problem here.
TIA.
- HMG Founder
is 'c:\hmg\BUILD.BAT' file on your system?nassausky wrote:I know this IDE has potential since I had wrote a few small programs already with the 2.94 IDE. I am having a problem though with HMG-IDE 3.0. Has anyone had an HMG-IDE error:
Mike
There is no file called Build.bat in c:\hmg or subfolders.
OK it is easy to reproduce.
1) I uninstalled Harbour MiniGUI 2.93 package and uninstalled 2.94 and 3.0 HMG IDE
2) I reinstalled Harbour MiniGUI 2.93 to c:\hmg
3) I installed HMG IDE 3.0 XIIB into c:\hmg-ide3
4) I set the hmg folder to c:\hmg in the preferences of the IDE 3.0
5) I restarted the IDE 3.0
6) I created a new folder c:\hmg\PROJECTS\mike4
7) I created a new project called mike4 and put it inside the above folder
8) I clicked Project then Run
9) I immediately got the error
Thanks,
Mike
Thanks,
Mike
_________________
Sincerely,
Mike
Sincerely,
Mike
