Which SQL is best to use
icjindal
Post by icjindal »
Dear Friends,
Some time ago, I was following thread on "Which SQL is best to use". This thread appears to be terminated without any conclusion. HMG community is still open on this point which IMHO,is very crucial for future of XBASE. Pl. conclude this issue.
IC Jindal
Re: Which SQL is best to use
IMHO, it is open because we can not come to a single conclusion.
Just like other software products, each of them is having its own advantages and disadvantages. Each one may have upper hand on portability, connectivity, security, networking.
With regard to me, I am using MysQL and don't have any problems with that. After that, I use SQLite. I wish I would try PostgreSQL and Firebird soon.
Hello IC Jindal,
Very happy to see your post :D How are you? :)
I also agree with Rathi. I am adding one point more. As MySql has some licensing problems, I decided to use other DBMS, eg., Sqlite, Pgsql, Firebird etc.
Currrently I am developing an application for a medium sized pharmaceuticals company with HMG300+SQLite :)
Again, our good old DBF (especially DBFCDX) has lots of power also. :)
It's very hard to say a single DBMS is best. Eg., for a small to medium sized DBMS, one may select SQLite, but for a large DBMS with many online users one may select PostgreSql ;)
claudiotedesco
Post by claudiotedesco »
Yo tambien quisiera empezar a utilizar SQL.
Que les parece si comienzo con Sqlite es mejor para empezar o me recomiendan otro?
Es facil de instalar? de donde lo descargo?
Si tienen algunos ejemplos para ir probando se los agradeceria.
Claudio
I also would like to start using SQL.
They think if I start with Sqlite is better to start or recommend me another?
It is easy to install? where I download it?
If you have some examples to get tested ?
Greetings
Claudio
Welcome.
Yes. It is fine for single user or small network.
It is already installed and bundled with HMG 3.0 ;)
You can find out working samples in HMG\samples\sqlite folder.
claudiotedesco wrote: If you have some examples to get tested ?
You may also check at (viewtopic.php?f=15&t=853) with lots of discussion from Master Roberto, Friend Rathi and other experienced friends of this forum :)
claudiotedesco
Hola Gente
Estuve viendo los ejemplo que estan en la carpeta HMG\samples\sqlite folder.
Lo ejecute sin inconveniente y lo veo muy util.
Pero me resulta un poco complejo entender bien las siguientes lineas, especialmente las que estan marcadas en rojo
function RefreshTable
sample.table.DeleteAllItems()
aTable := sql(dbo,"select * from new where date1 <= "+c2sql(ctod("15-04-2010")))
for i := 1 to len(aTable)
aCurRow := aTable
sample.table.additem({aCurRow[1],str(aCurRow[2]),str(aCurRow[3]),dtoc(aCurRow[4]),iif(aCurRow[5]==1,"True","False"),aCurRow[6]})
next i
if sample.table.itemcount > 0
sample.table.value := 1
sample.table.Refresh
return nil
Les agradeceria si me pueden explicar dicho uso
Claudio
claudiotedesco
I was watching the example that HMG are in the folder \ samples \ sqlite folder.
It runs without problem and I see it very useful.
But I find it a bit complex to understand well the following lines, especially those that are marked in red
aCurRow := aTable
next i
return nil
if I can explain this use
Greetings
Claudio
Actually this sql() function is a wrapper function. It returns a two dimensional array of the SQL query record set. It is in Row,Col format.
The red colored code is used to update a HMG grid with the SQL record set.
icjindal
Post by icjindal »
Friends,
I wish to opt for PostgreSQL. My all programmes are in Dos/Windows environment. On preliminary reading, I understand that PostgreSQL works best on Linux/ Unix OS. I have Ubuntu as 2nd OS on my laptop, along with Vista. Kindly guide me on this point.
IC Jindal
