Tool button without Picture clause
Should a tool button have picture definitely? Can't we omit the same?
In this toolbar_2 sample, I had omitted the picture for button 3_c and it gives run time error. :(
 * Copyright 2002 Roberto Lopez <harbourminigui@gmail.com>
#include "minigui.ch"
	DEFINE WINDOW Form_1 ;
		WIDTH 640 HEIGHT 480 ;
		TITLE 'MiniGUI ToolBar Demo' ;
		ICON 'DEMO.ICO' ;
		MAIN ;
		FONT 'Arial' SIZE 10
		DEFINE STATUSBAR
			STATUSITEM 'HMG Power Ready!'
		END STATUSBAR
		DEFINE MAIN MENU
			POPUP '&File'
				ITEM 'Get ToolBar_3 Button_1'	    ACTION MsgInfo ( if ( Form_1.Button_1c.Value , '.T.' , '.F.' ) , 'Button_1c' )
				ITEM 'Get ToolBar_3 Button_2'	    ACTION MsgInfo ( if ( Form_1.Button_2c.Value , '.T.' , '.F.' ) , 'Button_2c' )
				ITEM 'Get ToolBar_3 Button_3'	    ACTION MsgInfo ( if ( Form_1.Button_3c.Value , '.T.' , '.F.' ) , 'Button_3c' )
				ITEM 'Get ToolBar_3 Button_4'	    ACTION MsgInfo ( if ( Form_1.Button_4c.Value , '.T.' , '.F.' ) , 'Button_4c' )
	    			SEPARATOR
				ITEM 'Set ToolBar_3 Button_1'	    ACTION Form_1.Button_1c.Value := .T.
				ITEM 'Set ToolBar_3 Button_2'	    ACTION Form_1.Button_2c.Value := .T.
				ITEM 'Set ToolBar_3 Button_3'	    ACTION Form_1.Button_3c.Value := .T.
				ITEM 'Set ToolBar_3 Button_4'	    ACTION Form_1.Button_4c.Value := .T.
			    	SEPARATOR
				ITEM '&Exit'			ACTION Form_1.Release
			END POPUP
			POPUP '&Help'
				ITEM '&About'		ACTION MsgInfo ("MiniGUI ToolBar demo")
			END POPUP
		END MENU
		DEFINE SPLITBOX
			DEFINE TOOLBAR ToolBar_a BUTTONSIZE 45,40 FONT 'Arial' SIZE 8  FLAT
				BUTTON Button_1a ;
					CAPTION '&Undo' ;
					PICTURE 'button4.bmp' ;
					ACTION MsgInfo('Click! 1')
				BUTTON Button_2a ;
					CAPTION '&Save' ;
					PICTURE 'button5.bmp' ;
					WHOLEDROPDOWN
					DEFINE DROPDOWN MENU BUTTON Button_2a
						ITEM 'Exit'	ACTION Form_1.Release
						ITEM 'About'	ACTION MsgInfo ("MiniGUI ToolBar Demo")
					END MENU
				BUTTON Button_3a ;
					CAPTION '&Close' ;
					PICTURE 'button6.bmp' ;
					ACTION MsgInfo('Click! 3') ;
					DROPDOWN
					DEFINE DROPDOWN MENU BUTTON Button_3a
						ITEM 'Disable ToolBar 1 Button 1'	ACTION Form_1.Button_1a.Enabled := .F.
						ITEM 'Enable ToolBar 1 Button 1'	ACTION Form_1.Button_1a.Enabled := .T.
					END MENU
			END TOOLBAR
			DEFINE TOOLBAR ToolBar_b BUTTONSIZE 45,40 FONT 'ARIAL' SIZE 8 FLAT
				BUTTON Button_1b ;
					CAPTION 'More ToolBars...' ;
					PICTURE 'button7.bmp' ;
					ACTION MsgInfo('Click! 2');
				BUTTON Button_2b ;
					CAPTION 'Button 2' ;
					PICTURE 'button8.bmp' ;
					SEPARATOR
				BUTTON Button_3b ;
					CAPTION 'Button 3' ;
			END TOOLBAR
			DEFINE TOOLBAR ToolBar_c BUTTONSIZE 45,40 FONT 'Arial' SIZE 8 CAPTION 'ToolBar 3' FLAT
				BUTTON Button_1c ;
					CAPTION 'Check 1' ;
					ACTION MsgInfo('Hey!');
					CHECK GROUP
				BUTTON Button_2c ;
					CAPTION 'Check 2' ;
					ACTION MsgInfo('Hey!') ;
					CHECK GROUP
				BUTTON Button_3c ;
					CAPTION 'Check 3' ;
					SEPARATOR;
					CHECK GROUP
				BUTTON Button_4c ;
					CAPTION 'Help Check' ;
					PICTURE 'button9.bmp' ;
					CHECK
			END TOOLBAR
		END SPLITBOX
	CENTER WINDOW Form_1
	ACTIVATE WINDOW Form_1
Re: Tool button without Picture clause
rathinagiri wrote:Should a tool button have picture definitely? Can't we omit the same?
It's true.
Toolbar code could be changed to allow mixed toolbars with image buttons and non-image buttons work properly.
I'll work on it.
It's true.
I'll work on it.
Replacing c_toolbar.c and h_toolbar.prg with attached versions you could omit pictures on buttons.
Anyway, I guess that this is not a good thing.
TOOLBAR.RAR
(6.82 KiB) Downloaded 730 times
Oh. Thanks Roberto.
Again thanks for pointing out Roberto. I would specify a picture rather. :)
rathinagiri wrote:Oh. Thanks Roberto.
Ok. :)
In fact this error checking comes from a ToolBar bug report.
Someone reported a malfunction in ToolBar, but the fact was that the picture was missed :)
