Dynamic Colors in GRID
Hi to all
I can't succeed dynamically set/changing back and fore colors of GRID cells.
Here my unsucceed :( code :
#include "minigui.ch"
PROC Main()
    PRIV aGrdDFC   := ARRAY( 3 )      // GRID Dynamic Fore Colors
         aCitizens := {}
    DEFINE WINDOW Form_1 ;
        WIDTH 500 ;
        HEIGHT 400 ;
        TITLE 'Test Dynamic Colors' ;
        MAIN ;
        ON INIT FillGrid()
        DEFINE GRID Grid_1
            ROW     10
            COL     10
            WIDTH   450
            HEIGHT  330
            HEADERS {'Last Name','First Name','Phone'}
            WIDTHS  {140,140,140}
            ITEMS   { { '','',''} }
            VALUE   1
        END GRID
    Form_1.Center
    Form_1.Activate
RETU // Main()
PROC FillGrid()
  LOCA aItems :={ {'Simpson','Homer','555-5555' },;
                  {'Mulder','Fox','324-6432'},;
                  {'Smart','Max','432-5892'},;
                  {'Grillo','Pepe','894-2332'},;
                  {'Kirk','James','346-9873'},;
                  {'Barriga','Carlos','394-9654'},;
                  {'Flanders','Ned','435-3211'},;
                  {'Smith','John','123-1234'},;
                  {'Pedemonti','Flavio','000-0000'},;
                  {'Gomez','Juan','583-4832'},;
                  {'Fernandez','Raul','321-4332'},;
                  {'Borges','Javier','326-9430'},;
                  {'Alvarez','Alberto','543-7898'},;
                  {'Gonzalez','Ambo','437-8473'},;
                  {'Batistuta','Gol','485-2843'},;
                  {'Vinazzi','Amigo','394-5983'},;
                  {'Pedemonti','Flavio','534-7984'},;
                  {'Samarbide','Armando','854-7873'},;
                  {'Pradon','Alejandra','???-????'},;
                  {'Reyes','Monica','432-5836'} }
   Form_1.Grid_1.DeleteAllItems()
   AEVAL( aItems, { | a1 | Form_1.Grid_1.AddItem( a1 ) } )
   AEVAL( aItems, { | a1 | AADD( aCitizens, LEFT( a1[ 3 ], 1 ) == "5" ) } )
   AFILL( aGrdDFC, { || IF( aCitizens[ This.CellRowIndex ], RED, GREEN ) } )
   *** Form_1.Grid_1.DynamicForeColor := aGrdDFC  => syntax error at '.'
   SetProperty ( 'Form_1', 'Grid_1', 'DYNAMICFORECOLOR', aGrdDFC )
RETU // FillGrid()
Any opinion :?:
Re: Dynamic Colors in GRID
esgici wrote:Hi to all
Any opinion :?:
Hi Esgici,
Try the following working sample:
PROC Main()
    PRIV bColor1 := {|| NIL }
    PRIV bColor2 := { || if ( LEFT( This.CellValue, 1 ) == "5" , RED, GREEN ) }
        WIDTH 500 ;
        HEIGHT 400 ;
        MAIN ;
        ON INIT FillGrid()
        DEFINE GRID Grid_1
            ROW     10
            COL     10
            WIDTH   450
            HEIGHT  330
            VALUE   1
            DYNAMICFORECOLOR { bColor1, bColor1, bColor2 }
        END GRID
    Form_1.Center
    Form_1.Activate
RETU // Main()
PROC FillGrid()
RETU // FillGrid()
Thanks gfilatov.
This method is already used.
You are assigned value at design time.
This means that "DYNAMICxxxCOLOR property of GRID doesn't accept value at run time "?
esgici wrote:
gfilatov wrote: ...
esgici,
Sure. And reference should be updated as following
@...GRID / DEFINE GRID: Creates a grid control.
- Properties:
- DynamicBackColor (D)
- DynamicForeColor (D)
D: Available at control definition only
But the following sample have a trick:
PROC Main()
    PRIV bColor1 := {|| NIL}
        WIDTH 500 ;
        HEIGHT 400 ;
        MAIN ;
        ON INIT FillGrid()
        DEFINE GRID Grid_1
            ROW     10
            COL     10
            WIDTH   450
            HEIGHT  330
            VALUE   1
            DYNAMICFORECOLOR { bColor1, bColor1, bColor1 }
        END GRID
    Form_1.Center
    Form_1.Activate
RETU // Main()
PROC FillGrid()
  LOCA k := GetControlIndex( 'Grid_1', 'Form_1' )
   _HMG_SYSDATA [ 40 ] [ k ] [ 4 ] := { bColor1, bColor1, bColor2 }
   _HMG_DOGRIDREFRESH ( k )
RETU // FillGrid()
esgici,
Anyway, DynamicBackColor and DynamicForecolor data is stored in control arrays and could be easy, access to it to modify at runtime.
Besides, it could be a good idea to add support to it in SetPtoperty and GetProperty functions.
