English by Google
Hi:
I have an application that goes well in Windows XP and gives me
errors in Windows Vista.
Has anyone had this problem?
Why Windows Vista will need to compile and link in
a PC with Vista?
Greetings
jouhmg
Español
Hola:
Tengo una Aplicación que va bien en Windows XP y me da errores en Windows
Vista.
¿ Alguien ha tenido este problema ?
¿ Para Windows Vista será necesario compilar y enlazar en una PC con Vista ?
jouhmg
Different results (Resultados diferentes en) WXP y WV
- HMG Founder
Re: Different results (Resultados diferentes en) WXP y WV
I've worked for two years with Vista and now with Win7 (almost Vistajouhmg wrote:English by Google
Hi:
a PC with Vista?
Greetings
jouhmg
Español
Hola:
Vista.
jouhmg
English by Google
Hi:
Thanks Robert
Could it be that the errors that occur are caused because the installation of the PC has a Vista x86 on a x64 micro (Intel E5300)?
jouhmg
Español
Hola:
Gracias Roberto
¿ Puede ser que los errores que se producen estén ocasionados porque la instalación de la PC cuenta con un Vista x86 sobre un micro x64 (Intel E5300) ?
jouhmg
Hi:
Thanks Robert
jouhmg
Español
Hola:
Gracias Roberto
jouhmg
- HMG Founder
I don't know that such thing were even possiblejouhmg wrote:English by Google
Hi:
Thanks Robert
jouhmg
Español
Hola:
Gracias Roberto
jouhmg
En Windows XP
English by Google
Do we have any solution to be the same?
jouhmg
Español
¿ Tenemos alguna solución para que sean iguales ?
jouhmg
English by Google
jouhmg
Español
jouhmg
- DatePicker in Windows Vista with the same source code
- DPenWV.jpg (18.33 KiB) Viewed 3893 times
- DatePicker in Windows XP with the same source code
- DPenWXP.jpg (19.87 KiB) Viewed 3893 times
- HMG Founder
Allmost all the controls looks different on different Windows versions / themes.jouhmg wrote:En Windows XP
English by Google
jouhmg
I don't think that this is a problem at all.
Ok, fine.
Thanks Roberto.
Thanks Roberto.
