IDE 3.0 UPDATE
- HMG Founder
IDE 3.0 UPDATE
This new update features automatic formatting for 'Copy target to' configuration setting and read capability for report builder (only reports generated from this version can be read by the builder).
Enjoy!
Enjoy!
- ide_30_test_11e.rar
- (814.73 KiB) Downloaded 493 times
Re: IDE 3.0 UPDATE
Thanks Master for this new release.
Wtih best regards,
Wtih best regards,
Re: IDE 3.0 UPDATE
Hello Master Roberto,
I tested it. It works fine. Thanks a lot
I have some points. Please check those points in your off time
1) Add Form in Project menu.
2) Report editor for array. If there is any option to choose code editor for editing .rmg file, that will solve the purpose also.
- HMG Founder
Re: IDE 3.0 UPDATE
I'm thinking about that from some time ago.sudip wrote: 2) Report editor for array. If there is any option to choose code editor for editing .rmg file, that will solve the purpose also.
The problem is that such feature will impede preview, since IDE will be not able to reproduce the state of your applications variables. I'm thinking in an 'elegant' way to handle it
Re: IDE 3.0 UPDATE
Can you please add "Recent Projects" sub-menu in "File" menu of IDE
It will be great helpful for the programmers who are using more than one projects at the same time (like myself
Re: IDE 3.0 UPDATE
Working with reports I found that I can use dbf only from main folder of project. Meanwhile, I places my dbf files in subfolders to maintain order.
Now, I must copy my dbf file to main folder, then define report...
- HMG Founder
Re: IDE 3.0 UPDATE
Sudip, Marek,
I'm working now on give full functionality to report builder, when finish with that, I´ll consider other additions.
Both are interesting suggestions.
Re: IDE 3.0 UPDATE
I hope we are going to have final version of HMG 3.0.0 very soon
(But, please take your time and do your magical work as you like
- HMG Founder
Re: IDE 3.0 UPDATE
We do not have an HMG 3.0 final release until a Harbour 2.0 Harbour release be publishedsudip wrote:Hello Master Roberto,
(But, please take your time and do your magical work as you like)
