IDE 3.0 TEST XI (OTHER OTHER UPDATE)
- HMG Founder
There are three changes in this new test:
- Polish language support by Marek.
- New event procedure name defaults to <formname>_<controlname>_<eventname>
- New configuration option 'Copy target to:' allows to automatically store a copy of the app built in an additional path (I'm reading more:)).
Enjoy!
Enjoy!
- ide_30_test_11c.rar
- (813.53 KiB) Downloaded 428 times
Re: IDE 3.0 TEST XI (OTHER OTHER UPDATE)
Thanks a lot Maestro
Best Regards
Best Regards
Thanks Master for this wonderful release.
My best regards,
PS: (Veritas Filia Temporis), i agree with you.
My best regards,
- HMG Founder
Hi Master,Roberto Lopez wrote: ...
I´ve a little doubt, In "Copy target to:", spaces in the Path not are allowed?
My best regards,
AMAZINGRoberto Lopez wrote: ...
- HMG Founder
It writes a line in .hbc project file according hbmk2 syntax (instpaths=[paths]).Vanguarda wrote:Hi Master,Roberto Lopez wrote: ...
My best regards,
I've not tested with paths including spaces.
If does not work you could try using quotes.
I'm going offline right now. I'll test tomorrow.
I try with spaces, but it don´t work. I not be able with quotes too.Roberto Lopez wrote: It writes a line in .hbc project file according hbmk2 syntax (instpaths=[paths]).
Anyway, is a very nice function.
Thanks.
PS: Please so kindly, replace the PtBR.LNG, i´ve a little mistake... i already fix it.
- PtBR.rar
- (2.96 KiB) Downloaded 360 times
Super news!
I'll try it today.
Best regards, Marek
I'll try it today.
Best regards, Marek
- HMG Founder
It's solved now.Vanguarda wrote: I´ve a little doubt, In "Copy target to:", spaces in the Path not are allowed?
Please consider that path must end with a backslash and must be double quoted if contain spaces.
ie: If you target path is c:\test, you should write it as:
c:\test\Code: Select all
"c:\test x\"- Attachments
- ide_30_test_11d.rar
- (813.73 KiB) Downloaded 364 times
