Problem with Numeric Masked Textbox and 'On Change' event
Hello Roberto,
I have a bugreport about the following problem. :(
The Masked Textbox control execute 'On Change' procedure at the GotFocus and LostFocus events.
Reported by Marcelo Torres at the English minigui forum.
I guess that this problem is connected with management of the public switch variable _HMG_SYSDATA [ 253 ].
The demo sample is below: :arrow:
#include 'minigui.ch'
Function Main()
Local cUser
Local cPassword
DEFINE WINDOW Login ;
WIDTH 400 HEIGHT 200 ;
TITLE 'Login ' ;
MAIN ;
BACKCOLOR {192,192,192}
@045,070 LABEL Label_User ;
VALUE "Usuario " ;
WIDTH 120 ;
HEIGHT 35 ;
FONT "Arial" SIZE 09;
BACKCOLOR {192,192,192} ;
FONTCOLOR BLACK BOLD
@045,300 LABEL Label_chk_User ;
VALUE "" ;
WIDTH 120 ;
HEIGHT 35 ;
FONTCOLOR RED BOLD
@090,070 LABEL Label_Password ;
VALUE "Password " ;
WIDTH 120 ;
HEIGHT 35 ;
@090,300 LABEL Label_chk_pass ;
VALUE "" ;
WIDTH 120 ;
HEIGHT 35 ;
FONTCOLOR RED BOLD
@045,170 TEXTBOX p_User ;
HEIGHT 25 ;
VALUE cUser ;
WIDTH 120 ;
FONT "Courier" SIZE 09 ;
NUMERIC ;
INPUTMASK '99999' ;
ON ENTER IIf( !Empty( login.p_User.Value ) , Login.p_Password.SetFocus , Login.p_user.SetFocus ) ;
ON CHANGE fCambiaUser()
@090,170 TEXTBOX p_password ;
VALUE cPassWord ;
PASSWORD ;
TOOLTIP "Clave de Acceso" ;
ON ENTER Iif( !Empty( login.p_password.Value ) , Set_Logueo() , login.p_password.SetFocus )
@ 130,070 BUTTON Bt_Login ;
CAPTION '&Login' ;
ACTION Set_Logueo() ;
FONT "MS Sans Serif" SIZE 09 FLAT
@ 130,190 BUTTON Bt_Logoff ;
CAPTION '&Cancela' ;
ACTION Cancela_Logueo() ;
login.p_user.setfocus
CENTER WINDOW login
ACTIVATE WINDOW login
Function Set_Logueo()
MsgBox("funcion Set_Logueo")
Function Cancela_Logueo()
MsgBox("Cancela logueo")
Function fCambiaUser()
static n:=1
Login.title:="fCambiaUser"+str(n++)
Re: Problem with Numeric Masked Textbox and 'On Change' event
gfilatov wrote:Hello Roberto,
Thanks for the report Grigory.
I'll review it ASAP.
l3whmg
Post by l3whmg »
Hello,
I notice the same problem; attached you can find a simple program as an example.
While with the text field the clause "on change" works fine, with numeric field don’t work.
1) at the program start up “on change” begins operation (only for numeric field)
2) changing the value seems to enter an infinite loop
Thanks for your help.
chgtest.zip
(648 Bytes) Downloaded 797 times
Luigi from Italy
www.L3W.it
l3whmg wrote:Hello,
Thanks for the report.
