How to programmatically call the context menu?
I want to call context menu for browse, after searching record.
1. I don't want to define new window with buttons, because I placed all needed functions in context menu.
How to do it?
2. When I press context menu button on the kayboard, context menu appears in the right down corner of the sceen.
It doesn't look fine - detached from the component (especially in the browse - from current row).
Is it possible to control position of context menu on the screen?
Best regards, MAREK
Re: How to programmatically call the context menu?
mol wrote:How to programmatically call the context menu?
How to do it?
Best regards, MAREK
Is not clear to me the first part of your post.
Anyway, there is no high level implementation for this yet.
The function to call a context menu is:
TrackPopupMenu ( MenuHandle  , x , y , ParentWIndowHandle )
ParentWindow Handle is easy to get, the problem could be the MenuHandle.
You should first to get the form index in data array.
i := GetFormIndex ( cFormName )
ContextMenuHandle is in: _HMG_SYSDATA [ 74 ]
It should give you control about context menu.
Normally, you can call context menu using right mouse button or special key on the keyboard.
But I wanna call this menu after searching record automatically.
I've tried:
	i := GetFormIndex ( "OknoZlecenia" )
	ContextMenuHandle := _HMG_SYSDATA [ 74 ] [i]
	TrackPopupMenu ( ContextMenuHandle  , 50 , 50 , "OknoZlecenia" )
where:
OknoZlecenia - is the name of window
but... nothing happens.
What's wrong?
mol wrote:Normally, you can call context menu using right mouse button or special key on the keyboard.
I've tried:
where:
What's wrong?
No.
The last parameter should be GetFormHandle('OknoZlecenia')
I've tried:
where:
What's wrong?
Hi Marek,
Please be so kind to try the following working sample:
#include "minigui.ch"
Function main()
	DEFINE WINDOW Form_1 ;
		WIDTH 400 ;
		HEIGHT 200 ;
		TITLE 'Menu Test' ;
		MAIN
		DEFINE MAIN MENU
			POPUP 'File'
				ITEM 'Test' 		ACTION showcontext()
			END POPUP
			POPUP 'Help'
				ITEM 'About' 		ACTION MsgInfo ('Help:ABout')
			END POPUP
		END MENU
		DEFINE CONTEXT MENU
			ITEM 'Item 1' 		ACTION MsgInfo ('Item 1')
			ITEM 'Item 2' 		ACTION MsgInfo ('Item 2')
			SEPARATOR
			ITEM 'Item 3' 		ACTION MsgInfo ('Item 3')
		END MENU
	CENTER WINDOW Form_1
	ACTIVATE WINDOW Form_1
Function showcontext()
Local i, ContextMenuHandle, FormHandle
   i := GetFormIndex ( "Form_1" )
   FormHandle := _HMG_SYSDATA [ 67 ] [i]
   TrackPopupMenu ( ContextMenuHandle  , Form_1.Col + 50 , Form_1.Row + 50 , FormHandle )
I hope that helps :idea:
gfilatov wrote: Please be so kind to try the following working sample:
[/quote]
Thanks for the sample.
Following this, I wanna ask, if it is possible to determine screen position of selected row in the browse.
It will be superfine, when context menu will appear exactly under seected row...
I've reached satisfactory result.
Below modified code of Grigori sample:
PS. If somebody want to test it, remember to define Browse_1
Local i, ContextMenuHandle, FormHandle, nScreenRow, posx, posy
   i := GetControlIndex ( "Browse_1", "Form_1" )
   nScreenRow := LISTVIEW_GETFIRSTITEM ( _HMG_SYSDATA [3] [i] )
   posx := Form_1Row + Form_1.Browse_1.Row  + (nScreenRow+3) * (Form_1.Browse_1.FontSize + 1)
   posy := Form_1.Col + Form_1.Browse_1.Col + Form_1.Browse_1.Width/2
   TrackPopupMenu ( ContextMenuHandle  ,posy , posx, FormHandle )
Working with context menu, I think, it will be fine to define context menu for exact component, not for whole window.
maybe it's future?
