IDE 3.0 TEST IX
- HMG Founder
IDE 3.0 TEST IX
This test features the following changes:
- Project files (.hpj) has been replaced by '.hbp' files. These files contains only program modules names (.prg). To convert an existing project, change its extension from .hpj to .hbp and delete lines with form references (.fmg).
- Each project has now its own additional libraries, include paths and libraries paths. They are stored in a separate file with the same project basename with .hbc extension.
- Two new tabs in the project window, allows to edit project configuration and project include files.
- Only one command line parameter is allowed now, it indicates a project name to be opened at IDE startup.
- ide.cfg file was replace by three .ini files (editor.ini, hmg.ini and language.ini)
- Resource files and executables created has now the same basename as project (.hbp) file.
Download/Descarga: ide_30_test_09.rar
Enjoy!
Enjoy!
Re: IDE 3.0 TEST IX
Thanks a lot Roberto.
I think these structural changes will ease installation of new versions of IDE and building the projects efficiently.
Re: IDE 3.0 TEST IX
Thanks a lot Maestro
Best regards and hearty thanks
For me, this is biggest enhancement for this releaseRoberto Lopez wrote: <...>
- HMG Founder
Re: IDE 3.0 TEST IX
The basic idea is that all the samples, can be built and managed with ide, so the will be not more ide samples separated from others (command line build).rathinagiri wrote:Thanks a lot Roberto.
- HMG Founder
Re: IDE 3.0 TEST IX
Thanks!esgici wrote:Thanks a lot Maestro![]()
Best regards and hearty thanks![]()
Re: IDE 3.0 TEST IX
Finally, the end of the configuration editor to be used! I think, nobody uses MS notepad for editing text longer than one page.
All the changes are impressive!
Roberto, one question:
Do you have a time to sleep?
Best regards, Marek
Best regards, Marek
Re: IDE 3.0 TEST IX
I have one problem:
I've tested with my last project. I've placed new button in my main window, and it doesn't appears after compilation!
I think, they're still exist problems with hbmk2.
I've used BUILD.BAT from post from topic hmg 3 test VIII:
viewtopic.php?f=2&t=911&start=20
Can you check it?
I'll be back tomorrow.
Marke
Can you check it?
Marke
Re: IDE 3.0 TEST IX
thanks master.
i´ll test it.
my best regards,
i´ll test it.
my best regards,
- HMG Founder
Re: IDE 3.0 TEST IX
You could had changed the text editor in previous IDE versions too...mol wrote:Finally, the end of the configuration editor to be used! I think, nobody uses MS notepad for editing text longer than one page.
Not so much... my dog awakes me every day at 6 am. He comes with his ball to play with memol wrote:
Do you have a time to sleep?![]()
Best regards, Marek
- HMG Founder
Re: IDE 3.0 TEST IX
Since I've posted various patches, could be some confusion about which version of what component is being used to test.mol wrote:I have one problem:
Can you check it?
Marke
I'll publish a new test version including all patches. Please, re-test and if the problem persist, please post a sample.
TIA.
