Harbour MiniGUI 2.6.3:
English:
- Fixed: 'RangeMax' and 'RangeMin' properties not working when set
its values at runtime for Spinner control.
- Fixed: Incorrect dimensions in print preview windows under
Vista with 'Classic' theme.
- Fixed: 'Caption' property not working for ToolBar buttons.
- Fixed: Problem in print preview introduced in 2.6.2.
Español:
- Solucionado: Las propiedades 'RangeMax' y 'RangeMin' no funcionan
al intentar cambiar sus valores en tiempo de ejecución para el control
Spinner.
- Solucionado: Dimensiones de las ventanas de vista previa de
impresión en Vista con el tema 'Clásico'
- Solucionado: Problemas con la propiedad 'Caption' en los botones
de ToolBar.
- Solucionado: Problema en la vista previa de impresión introducido
en la versión 2.6.2.
Re: Harbour MiniGUI 2.6.3:
Hi Roberto
This is weekend and you are working hardly for us.
I can't know how I can thank you.
May God give you a long life.
Best Regards
Roberto Lopez wrote:English:
There is a small addition in the function SetProperty() for this fix:
		ElseIf Arg3 == 'CAPTION'
			IF GetControlType ( Arg2 , Arg1 ) == 'TOOLBUTTON'
				k := GetControlIndex ( Arg2 , Arg1 )
				_HMG_SYSDATA [ 33 ] [k] := Arg4   // Add here
				SetToolButtonCaption ( _HMG_SYSDATA [26] [k] , _HMG_SYSDATA [5] [k] , Arg4 )
			Else
It will correspond to code of the function _GetCaption() for ToolBar buttons 'Caption' property:
	If _HMG_SYSDATA [1] [i] == 'TOOLBUTTON'
		cRetVal := _HMG_SYSDATA [33] [i]
	Else
			Else
	Else
You are absolutely right.
Thanks.
I'll publish the fix in the next release.
