HMG 3.0.0 (Forum Test VI) Patch
- HMG Founder
This patch replaces build.bat and i_pseudofunc.ch.
- 300_test_VI_patch.rar
- (3.01 KiB) Downloaded 352 times
Re: HMG 3.0.0 (Forum Test VI) Patch
Thanks master
regards,
regards,
Hello,
Have you double clicked on BUILD.BAT ever? It will create a file named ".exe.exe"
- HMG Founder
I knowsudip wrote:Hello,
Have you double clicked on BUILD.BAT ever? It will create a file named ".exe.exe"![]()
Please, consider that is only a test release
Yes Master Roberto, only one point - I am using this "test" version with no problem
After three days with new version I didn't found any bug. But...
Today, I found problem in my one app (for printing invoices) - my client bought new printer for his office - HP OfficeJet 2280 (inkjet printer).
After installation - all invoices were printed OK - until poweroff computer.
The day after - nothing is printed from my app (from others every print seems to be ok).
Today I went to him to see what's going on. Really, no one invoice was printed.
After searching - I've changed in printer properties "Print Quality" from quick-draft to normal, and invoices start to print!
What's going on?
PS. Now, I'm using only laser printer and can't test it on inkjet printer.
If sb. have inkjet printer - please set quality of print to lowest and try to print from any application written with HMG.
What's going on?
- HMG Founder
Its very strange...mol wrote:After three days with new version I didn't found any bug. But...
What's going on?
HMG code is exactly the same as 2.9.5 excepting some little things regarding GT driver initialization that should not affect print system at all...
Please... if any new info appears, let me know...
Hello Master,
I found a small detail that does not change anything your great work.
But I would just inform you.
When I run the "build.bat" in the samples folder(per example), without passing any parameter. This generates a file with null name ".Exe.exe"
I applied all patches including this post viewtopic.php?f=5&t=899"
I added this line in my build.bat and the problem disappeared.
PS: Sorry my poor english
if exist .exe.exe del .exe.exeWith best regards,
- HMG Founder
Thanks.Vanguarda wrote:Hello Master,
PS: Sorry my poor englishCode: Select all
I'll try to fix ASAP.
I agree - it's strange - I've tested with app compile with bot hmg 295 and 300 - exactly the same effect.Its very strange...
I'll test it
