English:
- New: User Components Interface support. To test, copy files
in UCI folder to IDE startup folder (usually: \hmgide).
Be careful, this is under development yet.
Español:
- Nuevo: Soporte para Interface de Componentes de Usuario. Para probarlo, copiar los archivos de la carpeta UCI a la carpeta de inicio del IDE (usualmente: \hmgIde).
Harbour MiniGUI IDE 2.6.1
- HMG Founder
- luisvasquezcl
Re: Harbour MiniGUI IDE 2.6.1
Estimado Roberto,
no se activa el combobox con los controles de usuarios no se activa.
- HMG Founder
Luis,luisvasquezcl wrote:Estimado Roberto,
Tienes que copiar los archivos *.uci de la carpeta \hmgide\uci a \hmgide.
El combo se activa al editar un formulario.
Saludos,
- luisvasquezcl
Roberto,
habia copiado pero no habia abierto un form. .... ahora si funciona bien.
Excelente idea para cargar controles externos.
Felicitaciones.
Luis Vasquez
Felicitaciones.
Luis Vasquez
Hi Roberto
We have a problem in IDE-Form Designer:
This error occurs when attempted changing a control's name ( for GRID and COMBOBOX ) :
( xxx is the new control name attempted to give.)
In GRID :
Error BASE/1003 Variable does not exist: xxxHeaderImages
Called from __MVGET(0)
Called from UPDATECONTROLPROPERTIES(29118)
Called from SELECTCONTROL(4632)
Called from PROPERTYEDIT(8718)
Called from (b)MAIN(1264)
Called from EVENTS(2231)
Called from _DOMESSAGELOOP(0)
Called from _ACTIVATEWINDOW(4083)
Called from DOMETHOD(4114)
Called from OPEN(26446)
Called from EDITFILE(30327)
Called from (b)MAIN(1189)
Called from _DOCONTROLEVENTPROCEDURE(4394)
Called from EVENTS(1467)
Called from _ACTIVATEWINDOW(4037)
Called from MAIN(1297)
In COMBOBOX :
Error BASE/1003 Variable does not exist: xxxDroppedWidth
Called from UPDATECONTROLPROPERTIES(29037)
Called from PROPERTYEDIT(8235)
In GRID :
In COMBOBOX :
- HMG Founder
I'll review it ASAP.esgici wrote:Hi Roberto
Thanks for the report!
