Posts: 4023 Joined: Wed Jul 30, 2008 6:43 pm
Post
by Roberto Lopez » Wed Oct 14, 2009 3:25 pm
Hi all,
I've uploaded HMG 3.0 (Test IV) to SourceForge.
The problem is that the files takes a while until be 'visible' for download.
Please, check from time to time the 'View All files' section on HMG site at SourceForge and sooner or later you'll suceedd
- HMG 3.0.0 (Test IV) Changelog:
English:
- Updated: Harbour compiler to 2.0 (Created from SVN 2009.10.14).
HMG IDE 2.9.4 and earlier versions ARE NOT COMPATIBLE with this
HMG version.
- Updated: MingW compiler to 4.4.1
- Modified: Samples.
Removed: ADORDD samples (adordd not working on
current Harbour release)
Added: RDDSQL samples.
-\HMG\SAMPLES\RDD.SQL\MYSQL
-\HMG\SAMPLES\RDD.SQL\ODBC
-\HMG\SAMPLES\RDD.SQL\ARRAY
-\HMG\SAMPLES\MEMORY.TABLES
-\HMG\SAMPLES\MULTI.WIN
New: 'Build.bat' (it replaces 'compile.bat').
Syntax:
Build [/c] [/d] [/i] <PrgFile> | <filelist.hbp> [configfile.hbc]
[/c] : Console / Mixed Mode
[/d] : Debug Mode
[/i] : Incremental build
<filelist.hbp> : A text file with .hbp extension containing a source list.
<configfile.hbc>: A text file with configuration parameters as additional
libs, include paths and lib paths.
Sample: \HMG\SAMPLES\MULTI.WIN
Español:
- Actualizado: Harbour compiler a 2.0 (SVN 2009.10.12)
HMG-IDE versión 2.9.4 y anteriores no es compatible con esta versión
de HMG.
- Actualizado: MingW compiler a 4.4.1
- Modificado: Samples.
Eliminado: Ejemplos ADORDD (adordd no funciona en la
versión actual de Harbour)
Agregado:
Nuevo:'Build.bat' (reemplaza a 'compile.bat').
Sintaxis:
[/d] : Debug Mode
Ejemplo: \HMG\SAMPLES\MULTI.WIN
Posts: 5482 Joined: Tue Jul 29, 2008 6:30 pm
Post
by Rathinagiri » Wed Oct 14, 2009 4:31 pm
Thanks a lot Roberto.
Apart from uploading to sourceforge.net, you can upload to our site also (of course if your bandwidth permits).
Post
by Roberto Lopez » Wed Oct 14, 2009 4:56 pm
rathinagiri wrote: Thanks a lot Roberto.
The file size is about 14MB and I guess that we could be about 30 downloads on the first one/two days.
I don't know how that could impact your available bandwidth.
Post
by Roberto Lopez » Wed Oct 14, 2009 4:58 pm
'hmg300_Test3.exe' is still visible while I've deleted about one hour ago
The test 4 is not available for users either.
Post
by Rathinagiri » Wed Oct 14, 2009 6:58 pm
I had mentioned about uploading a copy of the file in our server through FTP connection. It depends upon your internet speed and cost. In that case, the file would be in our forum also.
Post
by Roberto Lopez » Wed Oct 14, 2009 7:53 pm
rathinagiri wrote: I had mentioned about uploading a copy of the file in our server through FTP connection. It depends upon your internet speed and cost. In that case, the file would be in our forum also.
Well... The file is available already:
http://sourceforge.net/projects/harbour ... e/download
So, by the moment, will be not necessary to upload it here.
Thanks for the offer.
Regarding my ISP costs, I pay a fixed monthly amount without traffic limits (1024/256 kbps) so, file sizes are not a problem.
