HMG 3.0 Test III
HMG 3.0 Test III
- HMG 3.0.0 Changelog:
English:
- Updated: Harbour compiler to 2.0 (Created from SVN 2009.10.12 ).
HMG IDE 2.9.4 and earlier versions ARE NOT COMPATIBLE with this
HMG version.
- Updated: MingW compiler to 4.4.1
- Modified: Samples.
Removed: ADORDD samples (adordd not working on
current Harbour release)
Added: RDDSQL samples.
-\HMG\SAMPLES\RDD.SQL\MYSQL
-\HMG\SAMPLES\RDD.SQL\ODBC
-\HMG\SAMPLES\RDD.SQL\ARRAY
Español:
- Actualizado: Harbour compiler a 2.0 (SVN 2009.10.12 ). HMG-IDE versión 2.9.4 y anteriores no es compatible con esta versión de HMG).
- Actualizado: MingW compiler a 4.4.1
- Modificado: Samples.
Eliminado: Ejemplos ADORDD (adordd no funciona en la
versión actual de Harbour)
Agregado: Ejemplos RDDSQL.
Download/Descarga:http://sourceforge.net/projects/harbour ... e/download
Enjoy!
Re: HMG 3.0 Test III
Thanks Roberto. :)
Vanguarda
Post by Vanguarda »
Thanks Master.
Thanks a lot Maestro :D
Best regards
Hello Master Roberto,
Thanks a lot! I tested with TEMPRARY TABLE using HB_DBCREATETEMP() function!!!! And it runs fine!!! :) (as of now I am testing with 3.0.0 Test II)
I cannot resist myself to show the codes. Codes were originally written by Grigory Filatov. Thank you Grigory :)
#include <minigui.ch>
	SET DELETED ON
	define window winMain ;
		at 0, 0 ;
		width 640 height 400 main ;
		title "Temporary Table" ;
		on init CreateTemp()
		DEFINE BROWSE brwTemp
			COL 0
			ROW 0
			WIDTH 600
			HEIGHT 340
			HEADERS {"Item Code", "Item Description", "Rate"}
			WIDTHS {125, 300, 100}
			WORKAREA curItem
			FIELDS {"curitem->itemcd", "curitem->itemnm", "curItem->rate"}
			ALLOWEDIT .T.
			INPLACEEDIT .T.
			ALLOWAPPEND .T.
			ALLOWDELETE .T.
			LOCK .T.
			JUSTIFY {0, 0, 1}
		END BROWSE
		@ 350, 0 label lblShow value "Alt-A: Add, Dbl-Click: Modify, Del: Delete" AUTOSIZE
	end window
	winMain.center
	winMain.activate
function CreateTemp()
	local aDbf := {}
	aadd(adbf,	{"itemcd", "c",	10, 0})
	aadd(adbf,	{"itemnm", "c",	40,	0})
	aadd(adbf,	{"rate",   "n",	 8, 2})
   if !hb_dbcreatetemp("curItem", adbf)
		msgbox("Cannot create temporary table: Item")
		RELEASE WINDOW ALL
		return nil
	if select("curItem") = 0
		use curItem new
	select curItem
	append blank
	curItem->itemcd := "CD"
	curItem->itemnm := "Compact Disc"
	curItem->rate := 10.00
	unlock
	return nil
	SET DELETED ON
		at 0, 0 ;
			COL 0
			ROW 0
			WIDTH 600
			HEIGHT 340
			WORKAREA curItem
			ALLOWEDIT .T.
			INPLACEEDIT .T.
			ALLOWAPPEND .T.
			ALLOWDELETE .T.
			LOCK .T.
			JUSTIFY {0, 0, 1}
		END BROWSE
	end window
	winMain.center
	winMain.activate
	local aDbf := {}
		RELEASE WINDOW ALL
		return nil
		use curItem new
	select curItem
	append blank
	unlock
	return nil
I'll add to the next release, adding appropriate credits for Grigory.
Thank you Master Roberto :)
IMHO, usability of temporary table with HMG 3.0.0 will dramatically increase the usability of BROWSE, at least to novice programmers like me.
We can use this facility with 1-to-many forms, storing query results from SQL database etc.
sudip wrote:Thank you Master Roberto :)
Hello Sudip,
The Harbour beta3 allows to use a true Memory File System besides of the temporary table which is created on the hard disk.
This feature based upon a new contribution HbMemIO by Mindaugas Kavaliauskas. :idea:
Take a look for the following sample (adapted for HMG):
 * Copyright 2002-2009 Roberto Lopez <harbourminigui@gmail.com>
 * Copyright 2009 Grigory Filatov <gfilatov@freemail.ru>
 * Based on MEMIO sample included in Harbour distribution
#include "minigui.ch"
REQUEST HB_MEMIO
Function Main()
	DEFINE WINDOW Form_1 ;
		WIDTH 640 HEIGHT 480 ;
		TITLE 'Memory File System Demo' ;
		MAIN NOMAXIMIZE ;
		ON INIT OpenTable() ;
		ON RELEASE CloseTable()
		DEFINE MAIN MENU
			DEFINE POPUP 'Test'
				ITEM "Exit"		ACTION ThisWindow.Release()
			END POPUP
		END MENU
		@ 10,10 BROWSE Browse_1	;
			WIDTH 610	;
			HEIGHT 390	;
			HEADERS { 'Code' , 'Name' , 'Residents' } ;
			WIDTHS { 50 , 160 , 100 } ;
			WORKAREA memarea ;
			FIELDS { 'Code' , 'Name' , 'Residents' } ;
			JUSTIFY { BROWSE_JTFY_LEFT, BROWSE_JTFY_LEFT, BROWSE_JTFY_RIGHT } ;
			EDIT ;
			INPLACE ;
			READONLY { .T. , .F. , .F. }
	CENTER WINDOW Form_1
	ACTIVATE WINDOW Form_1
Return nil
Procedure OpenTable
   CreateTable()
   INDEX ON FIELD->RESIDENTS TAG residents
   GO TOP
Procedure CloseTable
   DBCLOSEAREA()
   DBDROP("mem:test")  // Free memory resource
Function CreateTable
   DBCREATE("mem:test", {{"CODE", "C", 3, 0},{"NAME", "C", 50, 0},{"RESIDENTS", "N", 11, 0}},, .T., "memarea")
   DBAPPEND()
   REPLACE CODE WITH 'LTU', NAME WITH 'Lithuania', RESIDENTS WITH 3369600
   DBAPPEND()
   REPLACE CODE WITH 'USA', NAME WITH 'United States of America', RESIDENTS WITH 305397000
   DBAPPEND()
   REPLACE CODE WITH 'POR', NAME WITH 'Portugal', RESIDENTS WITH 10617600
   DBAPPEND()
   REPLACE CODE WITH 'POL', NAME WITH 'Poland', RESIDENTS WITH 38115967
   DBAPPEND()
   REPLACE CODE WITH 'AUS', NAME WITH 'Australia', RESIDENTS WITH 21446187
   DBAPPEND()
   REPLACE CODE WITH 'FRA', NAME WITH 'France', RESIDENTS WITH 64473140
   DBAPPEND()
   REPLACE CODE WITH 'RUS', NAME WITH 'Russia', RESIDENTS WITH 141900000
Hello Grigory,
Thanks a lot :)
But, I can't compiled the code:
Harbour 2.0.0beta3 (Rev. 12422)
Copyright (c) 1999-2009, http://www.harbour-project.org/
Compiling 'demo.prg'...
Lines 12105, Functions/Procedures 4
Generating C source output to 'demo.c'... Done.
demo.o:demo.c:(.data+0x1c8): undefined reference to `HB_FUN_HB_MEMIO'
May be I have done some careless mistakes (again) ;)
sudip wrote:Hello Grigory,
Thanks a lot :)
You must link libhbmemio.a.
You must modify compile.bat to add it.
I'll link by default from next test release.
