GIRD Control need KEYPRESS Event.
When USER press any key (range A-Z,0-9) on GRID a KEYPRESS event should fire carring with Key pressed value.
Hi Rathi,
Please let me know if already exists this event.
Thanks in Advance.
Shridhar
- HMG Founder
Re: GIRD Control need KEYPRESS Event.
It's a good idea.shridhar wrote:GIRD Control need KEYPRESS Event.
Hi Rathi,
Thanks in Advance.
Shridhar
Anyway, please consider that you alway could use ON KEY command.
In the ON KEY procedure you've defined, you could ask for 'FocusedControl' property, to know if (ie) a grid is focused in the current window and code it as you need.
Thanks for the info Roberto.
Same way, can we capture mouse clicks also in a global way?
- HMG Founder
OnMouseClick window event works only over windows 'surface'.rathinagiri wrote:Thanks for the info Roberto.
Controls capture mouse, so this event do not work inside controls.
Anyway, usually you don't need to capture mouse in controls, since the default action is the one desired (ie: button click).
Thanks Roberto. In that case, can the mouse click event outside a modal window (ie., trying to go out from Modal window) be captured?
- HMG Founder
I'm not sure... I'll should research it to give a right answer...rathinagiri wrote:Thanks Roberto. In that case, can the mouse click event outside a modal window (ie., trying to go out from Modal window) be captured?
Thanks Master..
Shridhar
Shridhar
Hi Master,
Could you please inculde this KEYPRESS event in the 2.9.6 release ?
Thanks in Advance...!
Shridhar
Shridhar
