ALIAS not working
arturo_lopesoria
ALIAS not working
Post by arturo_lopesoria »
I think is a bug:
I was probed it with V.2.9.3 & V2.9.4
cFileGVA := GetFile( , "Archivo de Articulos" , "c:\" , .f., .f. )
if empty(cFileGVA)
   return .f.
use (cFileGVA) alias ARTICS
if !used()
   msginfo("no se abrio;"+cFileGVA)
   return .f.
select ARTICS  // AQUI MARCA ERROR ALIAS DOES NOT EXIST ARTICS
I was probed this way too:
        dbUseArea( .T., "DBFCDX", cFileGVA, "ARTICS", lShared, lReadOnly )
EN ESTE ULTIMO CASO MARCA ERROR DE ARGUMENTO
Re: ALIAS not working
arturo_lopesoria wrote:I think is a bug:
if empty(cFileGVA)
   return .f.
if !used()
   return .f.
In the case that the problem be verified, it will be (eventually) a Harbour compiler bug.
MiniGUI library is not related with dbf handling at all.
Hola Arturo:
¿verificaste si getfile() devuelve el archivo con el path completo?
otra cosa ... creo que el último parametro de la funcion dbusearea 'lreadonly' no se necesita ya que si abres la tabla y en el control donde la muestras los registros no permites que se edite, no podran hacer nada ;) .
saludos cordiales,
Luis Vasquez.
Try to insert
MsgBox(cFileVGA)
after instruction:
GetFile...
You will see if cFileVGA contains whole path to database or only database filename....
I'm using aliases and they don't cause any error.
Always worked good
arturo_lopesoria
Excuse me
First I was thinking it was a harbour bug, but now Im sure there is an error on my code..
I put same code in a single program and ALIAS is working fine.. Sorry.
Thanks all of you for your ideas and support..
Saludos desde Mexico.
Arturo LS
