control serial port (ex: nt250.lib norton)
perenne
Post by perenne »
Want to put this in libhbcomm.a in HMG ?
Where to find libhbcomm.a for download ?
Re: control serial port (ex: nt250.lib norton)
perenne wrote:Want to put this in libhbcomm.a in HMG ?
I've googled that and I've found this:
http://www.fivewin.com.br/forum/post.as ... %E9+%3F&M=
You can include the code (from BEGINDUMP to ENDDUMP) in any .prg file and compile as usual .
I've not tested.
I've not tested.
This is the code:
#pragma BEGINDUMP
The Harbour interface routines for the HBCOMM library. It is not clear who
produced the harbour routines to interface with Harold Howe's TCommPort
encapsulation. Regardless, the Harbour interface has been modified to
allow for more than one port to be open (MAXOPENPORTS) compiled at 20 and
to allow for the sending and receiving of data containing NULL characters
(Chr(0)).
As a C/C++ coder, I make a fair plumber. Anyone who wishes to clean-up my
code is welcome to do so.
Ned Robertson
XpertCTI, LLC
Richmond, VA USA
July, 2003
#include "hbapi.h"
#include "hbcomm.h"
static int aHandles[ MAXOPENPORTS ] ; // assumes initialized to zeros
static int nHBase = 256 ;
// ÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄ //
HB_FUNC(INIT_PORT) /* Nx_port(string),Nbaud(numerico),Ndata(numerico),Nparity(numerico),Nstop(numerico),nBufferSize(numerico)
retorna .t. se abriu a porta */
/* cPort, nBaudrate, nDatabits, nParity, nStopbits, nBuffersize
Main initiator/port opener.
cPort may take either the form 'COMn' or the more general '\\.\COMn'
The more general form is required for port numbers > 9.
nParity codes: 0,1,2,3 -> none, odd, mark, even
nStopBits codes: 0,1,2 -> 1, 1.5, 2
Returns a "handle" >= 256. A return of -1 means open failed.
The handle must be used on all references to the port and is equivalent to
nComm used in 16 bit Clipper/Fivewin routines. All routines take the
handle reference as their first argument.
int i = 0, n = -1, nHandle ;
while ( n < 0 && i < MAXOPENPORTS ) {
if ( aHandles[ i++ ] == 0 )
n = i - 1 ;
if ( n != -1 ) {
nHandle = nHBase++ ;
aHandles[ n ] = nHandle ;
if ( hb_init_port( n, hb_parc( 1 ) , hb_parnl( 2 ) ,
hb_parnl( 3 ) , hb_parnl( 4 ) , hb_parnl( 5 ) ,
hb_parnl( 6 ) ) )
hb_retnl( nHandle ) ;
hb_retnl( 0 ) ;
HB_FUNC( OUTBUFCLR ) // purge output buffer -> Limpeza da Saida do Buffer
int nIdx ;
nIdx = FindIndex( hb_parnl( 1 ) ) ;
if ( nIdx != -1 ) {
hb_outbufclr( nIdx ) ;
hb_retl( TRUE ) ;
hb_retl( FALSE ) ;
HB_FUNC( ISWORKING ) // See if port is opened correctly
int nIdx ;
if ( nIdx != -1 )
hb_retl( hb_isworking( nIdx ) );
hb_retl( FALSE ) ;
HB_FUNC( INCHR ) // fetch hb_parnl( 2 ) chars into hb_parc( 3 )
int nIdx ;
if ( nIdx != -1 )
// hb_retc( hb_inchr( nIdx, hb_parnl( 1 ) ) );
hb_retnl( hb_inchr( nIdx, hb_parnl( 2 ), hb_parc( 3 ) ) ); // EDR*7/03
hb_retnl( 0 ) ;
HB_FUNC( OUTCHR ) // Send out characters. Returns .t. if successful.
int nIdx ;
if ( nIdx != -1 )
// hb_retl( hb_outchr( hb_parc( 1 ) ) );
hb_retl( hb_outchr( nIdx, hb_parc( 2 ), hb_parclen( 2 ) ) ); // EDR*7/03
hb_retl( FALSE ) ;
HB_FUNC( INBUFSIZE ) // Find out how many chars are in input buffer
int nIdx ;
if ( nIdx != -1 )
hb_retnl( hb_inbufsize( nIdx ) );
hb_retnl( 0 ) ;
HB_FUNC( OUTBUFSIZE ) // Find out how many characters are in out buf ?
int nIdx ;
if ( nIdx != -1 )
hb_retnl( hb_outbufsize( nIdx ) );
hb_retnl( 0 ) ;
HB_FUNC( UNINT_PORT ) // Close port and clear handle
int nIdx ;
if ( nIdx != -1 ) {
hb_unint_port( nIdx );
aHandles[ nIdx ] = 0 ;
hb_retl( TRUE ) ;
hb_retl( FALSE ) ;
int FindIndex ( int nH ) // Convert "handle" to tcomm array index
int i = 0, n = -1 ;
if ( aHandles[ i++ ] == nH )
n = i - 1 ;
// printf( "index= %8d\n", n );
return n ;
HB_FUNC( CHKIDX ) // For debugging - not normally used
int nIdx ;
hb_retnl( nIdx );
#pragma ENDDUMP
perenne
Post by perenne »
Thank you for responding,
I put the code from BEGINDUMP to ENDDUMP and gave the following error:
C:\visual\HBCOMM\Demo\MAIN.o:MAIN.c:(.text+0x1e9): undefined reference to `hb_init_port'
C:\visual\HBCOMM\Demo\MAIN.o:MAIN.c:(.text+0x23c): undefined reference to `hb_outbufclr'
C:\visual\HBCOMM\Demo\MAIN.o:MAIN.c:(.text+0x286): undefined reference to `hb_isworking'
C:\visual\HBCOMM\Demo\MAIN.o:MAIN.c:(.text+0x2ef): undefined reference to `hb_inchr'
C:\visual\HBCOMM\Demo\MAIN.o:MAIN.c:(.text+0x35c): undefined reference to `hb_outchr'
C:\visual\HBCOMM\Demo\MAIN.o:MAIN.c:(.text+0x3a6): undefined reference to `hb_inbufsize'
C:\visual\HBCOMM\Demo\MAIN.o:MAIN.c:(.text+0x3ec): undefined reference to `hb_outbufsize'
C:\visual\HBCOMM\Demo\MAIN.o:MAIN.c:(.text+0x432): undefined reference to `hb_unint_port'
ng C source output to 'C:\visual\HBCOMM\Demo\MAIN.c'... Done.
mingw32-make.exe: *** [C:\visual\HBCOMM\Demo\MAIN.exe] Error 1
Finished With Errors.
hbcomm.h downloaded from "www.carozodequilmes.com.ar/Projects/QAC/"
thanks!
