Can I cancel?
Can I cancel?
Suppose I start a time consuming operation (say indexing some 50 BIG tables) and I want to interrupt/cancel in between.
How can we do that? Can we have a button to interrupt and stop a running function?
S. Rathinagiri.
Re: Can I cancel?
rathinagiri wrote:Hi,
S. Rathinagiri.
It depends on function.
If you are talking about you own function (ie: indexing tables) you could use DO EVENTS between calls to DBCREATEINDEX() function.
If you mean interrupt DBCREATEINDEX() function itself, I'm not sure. Perhaps...
 DBCREATEINDEX(<cIndexName>, <cKeyExpr>,
        [<bKeyExpr>], [<lUnique>]) --> NIL
<bKeyExpr> is a code block that expresses the index key expression in executable form
...using a 'tricked' <bKeyExpr> including a call to ProcessMessages().
Anyway, I've never used <bKeyExpr> parameter, so, I don't know if it is possible
Re: Can I cancel?
Oh! Thanks for the tip Roberto. :)
I wanted to break my own function many times. :)
