HMG IDE 2.9.4 (Forum Test II)
Enhancements to report builder:
- Custom Fields / Expressions
- Custom Fonts (Name / Size / Style)
- Various interface changes
- Various bug fixes
ide294test2.rar
(757.85 KiB) Downloaded 431 times
Vanguarda
Re: HMG IDE 2.9.4 (Forum Test II)
Post by Vanguarda »
Thanks master for this new release
with best regards,
Hello Master Roberto,
Thank you for this version. Downloaded it. I shall confirm after testing.
Regards.
Thanks Roberto.
Thanks! It runs Ok! :)
Regards.
fchirico
Post by fchirico »
Roberto Lopez wrote:Hi All,
- Various bug fixes
Gracias, probado y funcionando!
Saludos, Fernando Chirico.
Excelente,
muchas gracias por tu constancia.
Saludos cordiales,
Luis vasquez
Estimado Roberto,
probando el informe cuando pones 2 campos de texto produce problemas.
en mi caso, puse test->First+' '+test->last y resultó la imagen que adjunto.
Deben tener cuidado cuando pones un espacio separando 2 campos de texto. Debes poner comillas simples ya que el report genera una cadena encerrada entre comillas dobles.
saludos cordiales,
Luis Vasquez
saludos cordiales,
Luis Vasquez
English:
I'm not fully sure about you've done.
Where exactly had you write test->First+' '+test->last ?
Español:
No estoy completamente seguro de lo que hiciste.
¿Donde exactamente escribiste test->First+' '+test->last?
Saludos/Regards
saludos cordiales,
Luis Vasquez
And...
In this first version, the report builder, does a simple job.
It assigns to each field the same width. The width is calculated according the selected field count and current page width.
So, if the calculated field width is not enough, you will be in trouble :)
Anyway, you can change the font type and size, and eventually use a 'custom field' to make the field narrow (ie: Left(field,..) ).
