QBE with MySql (an idea)
Re: QBE with MySql (an idea)
Thanks for your comments on Firebird.
Can you tell me why you prefer ODBC to connect to Firebird?
What about the native API?
Hello Friend Vanguarda,
Thanks a lot for your answer.
Now, I also want to know like Rathi, which is YOUR CHOICE between native API call and ODBC? And pros and cons about 2 methods.
Thank you again.
I am very happy to hear this. So, Master Roberto gave us a software tool free of cost which has the same performance of a highly priced and excellent software tool!!! Thank you Roberto. Your software is pricelessVanguarda wrote: Some time ago (4 years may be), i had work with firebird and xHarbour Comercial Version + SQLRDD. Currently i work with firebird + ODBC + HMG and the performance is was like with xHarbour.
Thank you again.
Hi my friends SUDIP, Rathi.rathinagiri wrote:Can you tell me why you prefer ODBC to connect to Firebird?
At first, sorry my delaying for response.
Well, I prefer ODBC because this way is the ONLY way that i was able for connect to firebird
ONLY way free. Because the SQLRDD driver is very, very expensive for me. And with ODBC i was very glad. The performace is the same.
sorry friends, but i don´t know about this NATIVE API.
with best regards,
Thanks Vanguarda.
Recently Roberto had added connectivity to various databases like SQLite, MySQL, Firebird, Postregsql from harbour source code. They are already inbuilt with the name lib*.a in c:\hmg\harbour\lib folder.
For Firebird the library is libhbfbird.a. With this library we can easily connect to the Firebird databases without any ODBC connection. Since it is a direct connection it should be faster than ODBC, I think.
Here is the example code to how to connect and access Firebird database from Harbour source code,
* $Id: test.prg 8659 2008-06-08 10:22:37Z vszakats $
#include "common.ch"
Function Main()
LOCAL cDir, cName
LOCAL cDBName
LOCAL nDialect := 1
LOCAL trans, qry
hb_FNameSplit( hb_argv( 0 ), @cDir, @cName, NIL )
cDBName := hb_FNameMerge( cDir, cName, ".gdb" )
if File( cDBName )
FErase( cDBName )
? FBCreateDB(cDBName, 'sysdba', 'masterkey', 1024, 'ASCII', nDialect )
/* Connect rdbms */
db := FBConnect("127.0.0.1:" + cDBName, "sysdba", "masterkey")
if ISNUMBER(db)
? 'Error'
quit
? FBExecute(db, 'sldjfs;ldjs;djf', nDialect)
? FBClose(db)
trans := FBStartTransaction(db)
qry := FBQuery(db, 'create table teste (code smallint)', nDialect, trans)
FBCommit(trans)
? "Status Execute: ", FBExecute( db, 'insert into customer(customer) values ("test 1")', nDialect, trans)
? "Status no Rollback: ", FBRollback(trans)
? "Status Execute: ", FBExecute( db, 'insert into customer(customer) values ("test 2")', nDialect, trans )
? "Status commit: ", FBCommit(trans)
? "Status Execute: ", FBExecute( db, 'insert into customer(customer) values ("test 3")', nDialect )
// FIX WINDOWS GPF BELOW
qry := FBQuery(db, "SELECT * FROM sales", nDialect)
num_cols := qry[4]
columns := qry[6]
For x := 1 to num_cols
? x, "> "
For y := 1 to len(columns[x])
?? columns[x,y], ' '
Next
Next
do while (fetch_stat := FBFetch(qry)) == 0
? fetch_stat
for x := 1 to num_cols
?? FBGetData(qry,x), ', '
next
enddo
? 'Fetch code:', fetch_stat
? "Status Free sql: ", FBFree(qry)
/* Close connection with rdbms */
? "Status Fechar Database: ", FBClose(db)
I had linked a sample file using the provided libhbfbird.a. It gives error.
We have to create libfbclient.a (by converting fbclient.dll distributed with firebird) or use the fbclient.dll and ibase.h in our software. I don't know how to do that.
hi friends,
Rathi, thanks for the info. Is is a great new. I´ll test it ASAP.
with best regards,
with best regards,
Hello Vanguarda,
Hope you will be interested about this link viewtopic.php?f=7&t=860Vanguarda wrote:....
Because the SQLRDD driver is very, very expensive for me ...
Thank´s a lot my friend,sudip wrote:Hello Vanguarda,Hope you will be interested about this link viewtopic.php?f=7&t=860Vanguarda wrote:....
regards,
