RESTalk REST + JSON + DOM
Hola a todos:
les dejo una version REST API + JSON + DOM basado en la app
* Simple Server for test with NETIO
* Created by : Paulo Sérgio Durço - 23/10/2009 8:30 Hrs
* Thanks Master Roberto Lopez for your great work.
API info.png (24.74 KiB) Viewed 228 times
API Chat.png (21.71 KiB) Viewed 228 times
Re: RESTalk REST + JSON + DOM
Todavia tengo errores que tengo que corregir.
1- Salida
2. Descubridor UDP del SERVER
compilar con Build64 , si necesitan ayuda voy a generar el build.bat dentro de la carpeta
RESTalk.rar
(44.88 KiB) Downloaded 19 times
Build.bat
para RESTalk
@ECHO OFF
SETLOCAL
SET Temp1=%~dp0
SET Temp3=%Temp1%&SET Pos=0
:Loop
SET /a Pos+=1
ECHO %Temp3%|FINDSTR /b /c:"SAMPLES" >NUL
IF ERRORLEVEL 1 (
SET Temp3=%Temp3:~1%
IF DEFINED Temp3 GOTO Loop
SET Pos=0
SETLOCAL EnableDelayedExpansion
SET "Temp2=%Temp1%"
SET /a Pos=Pos-2
SET Temp1=!Temp2:~0,%Pos%!
IF "%1"=="" GOTO WithOutParam
SET MainFile="%1"
GOTO WithParam
:WithOutParam
:: Compilación secuencial en orden estricto: Servidor y luego Cliente
IF "%NoRun%"=="" (
    ECHO Building TalkServer.hbp...
    CALL %Temp1%\build64.bat TalkServer.hbp
    ECHO.
    ECHO Building TalkClient.hbp...
    CALL %Temp1%\build64.bat TalkClient.hbp
) ELSE (
    ECHO Building TalkServer.hbp ^(NoRun^)...
    CALL %Temp1%\build64.bat /n TalkServer.hbp
    ECHO.
    ECHO Building TalkClient.hbp ^(NoRun^)...
    CALL %Temp1%\build64.bat /n TalkClient.hbp
GOTO End
:WithParam
IF "%NoRun%"=="" CALL %Temp1%\Build.bat %MainFile%
IF NOT "%NoRun%"=="" CALL %Temp1%\Build.bat /n %MainFile%
:End
el .Rar descomprimir en
C:\hmg.3.6\SAMPLES\Advanced
Steed
Post by Steed »
Gracias
