VisionEngine Library
Hola a todos:
En base a una libreria que esta en GitHub de libre uso y en mis tiempo libres me propuse implementar el uso de una simple WEBCAM con el otro proyecto llamado Zbar.
Hello everyone: based on a library that is on GitHub for free use and in my free time I decided to implement the use of a simple WEBCAM with the other project called Zbar.
Links:
https://github.com/sipsorcery/mediafoun ... pleGrabber
https://linuxtv.org/downloads/zbar/bina ... 64-VfW.zip
despues de muchos dias luchando con Gemini porque ya tenia el SampleGrabber integrado y exportado todas sus funciones
seguia sin tener la imagen dentro del formulario HMG.
Leyendo foros encuentro que MF (Media Fundacion) no genera Ventana de video,
por eso no tenia video.. Basandome en foros y la ayuda de ChatGPT resumi SampleGrabber.cpp, SampleGrabber.h en VisionEngine.cpp
una libreria que comparto con uds para integarlo en cualquier proyecto.
After struggling for days because I already had the SampleGrabber integrated and all its functions exported, I still couldn't get the image to appear inside the HMG form.
While researching various forums, I discovered that Media Foundation (MF) does not automatically generate a video window, which is why the video wasn't rendering.
Based on forum discussions and some AI assistance, I refactored and consolidated SampleGrabber.cpp and SampleGrabber.h into a single library called VisionEngine.cpp. I am sharing this library with the community so it can be easily integrated into any project.
Rar ------------------------>
VisionEngine.rar
(1.91 MiB) Downloaded 40 times
Sin título.png (21 KiB) Viewed 483 times
-Compilation-
Command line :
cd c:\VisionEngine\Source
Command line :
set path=%path%;c:\mingw64\bin
Command line :
BuildLib
- Result -
Compilando VisionEngine... | Compiling VisionEngine...
Generando Librería... | Generating Library...
Verificando exports Harbour... | Verifying Harbour exports...
00000000000010e0 T HB_FUN_SCAN_CLEAR_RESULT
0000000000001270 T HB_FUN_SCAN_CLEARBUFFERDIRTY
0000000000001240 T HB_FUN_SCAN_CLEARBUFFERFLAG
0000000000001410 T HB_FUN_SCAN_COUNTDEVICE
00000000000010c0 T HB_FUN_SCAN_GETBARCODE
0000000000001150 T HB_FUN_SCAN_GETBUFFER
0000000000001280 T HB_FUN_SCAN_GETDEVICENAME
00000000000010d0 T HB_FUN_SCAN_GETTYPE
00000000000010b0 T HB_FUN_SCAN_IS_ACTIVE
0000000000001250 T HB_FUN_SCAN_ISBUFFERDIRTY
0000000000001120 T HB_FUN_SCAN_SETMODE
00000000000025b0 T HB_FUN_SCAN_SNAPSHOT
0000000000001070 T HB_FUN_SCAN_START
0000000000001090 T HB_FUN_SCAN_STOP
0000000000001400 T HB_FUN_VISION_GET_VERSION
0000000000001060 T HB_FUN_VISION_IS_RUNNING
0000000000001040 T HB_FUN_VISION_SETPREVIEWWINDOW
0000000000000ff0 T HB_FUN_VISION_START
0000000000001020 T HB_FUN_VISION_STOP
LISTO | DONE
ya sabes usar el IDE asi que abres el proyecto y compilas :)
You know the IDE , so just open the project and run the build :)
"Warning: Ensure the project folder has write permissions. A read-only directory will lead to application crashes."
Re: VisionEngine Library
Nota :
:( ajustado para 640x480 :(
Thanks Daniel !
Steed
Post by Steed »
Thanks
Hola a Todos !!!
Mientras tengo tiempo como Piercer ( mi actual trabajo ) deje la electronica y programacion (despues de 30 años de actividad) volvi con ese proyecto que surgio de una pregunta en el foro...
cambie el rumbo de la app que escanea un codebar (con ayuda de Zbar "Todos") pero en la logica solo EAN13 y QR, veia que funcionaba pero era muy lineal y contenia errores que IA corrigio.. asi que como siempre me gusto leer sobre threads y pedirle a la IA ejemplos de usos para ver su funcionamiento lleve a VisionEngine a VisionEngineMT ...esto es Interfaz de usuario despegado del motor (MF + Zbar y proximamente HBZEBRA!!!!)
se los dejo para su uso !!!!
los leo y gracias por compartir sus experiencias en cada post dentro del Foro... lastima que en el camino van quedando los viejos Clipperos :|
Hello everyone!
While I have some free time as a Piercer (my current job), I've put electronics and programming aside (after 30 years in the field). I've returned to a project that originated from a question on the forum... I changed the direction of the app that scans barcodes (using Zbar "Todos"), but in the logic, it only handles EAN13 and QR codes. I saw that it worked, but it was very linear and contained errors that AI corrected. So, as I always enjoy reading threads and asking AI for usage examples to see how it works, I brought VisionEngine to VisionEngineMT... This is a user interface detached from the engine (MF + Zbar and soon HBZEBRA!!!!)
I'm sharing it with you for your use!
I read your posts and thank you for sharing your experiences in each one on the forum... It's a shame that the old Clippers are being left behind.
open cmd:
cd c:\VisionEngineMT\Source
BuildLib
Result
CLEAN OBJECTS
COMPILING ENGINE
COMPILING BRIDGE
BUILD STATIC LIB
EXPORT CHECK
0000000000000220 b _ZZ12Vision_GetQRE3out
0000000000000320 b _ZZ20Vision_GetDeviceNameE4name
00000000000015c0 T Vision_CountDevices
0000000000000cb0 T Vision_GetDeviceName
0000000000000e20 T Vision_GetLog
0000000000000f60 T Vision_GetQR
00000000000015a0 T Vision_GetType
0000000000001590 T Vision_HasNewQR
0000000000000be0 T Vision_Init
0000000000000fe0 T Vision_SaveSnapshot
0000000000001580 T Vision_SetDebug
00000000000015b0 T Vision_SetFrame
0000000000000f00 T Vision_SetPreviewWindow
0000000000000e30 T Vision_Stop
                 U Vision_CountDevices
                 U Vision_GetDeviceName
                 U Vision_GetLog
                 U Vision_GetQR
                 U Vision_GetType
                 U Vision_HasNewQR
                 U Vision_Init
                 U Vision_SaveSnapshot
                 U Vision_SetDebug
                 U Vision_SetFrame
                 U Vision_SetPreviewWindow
                 U Vision_Stop
Open your IDE and compile in 64-bit mode
Proyect --->
VisionEngineMT.rar
(1.91 MiB) Downloaded 35 times
📄 Vision.log – Technical Reference
Overview
vision.log is a runtime diagnostic log file generated by the VisionEngineMT system. It records high-level system events, including initialization, shutdown, camera status, and barcode detection results.
The log is designed for debugging, system monitoring, and post-run analysis of the Vision Engine pipeline.
Thanks Daniel !
franco
Post by franco »
Thanks Daniel ...
All The Best,
Franco
Canada
Hola a todos, hoy mi trabajo actual me deja tiempo disponible para revisar mis app o app ejemplos.
Visionengine se convirtio en VisionEngineMT por Multitreath (multi hilos en el motor Zbar) como Zbar es muy viejo (data de 2012) decidi usar ZXing, asi que elimime todo rastro de Zbar del ejemplo.
como no encuentro mi camara web homebrew (echo en casa) sacada de una vieja notebook, decidi implementar que se pueda tambien decodificar desde una imagen el codebar o codigo de barras.
quien tenga la amabilidad de compilar el ejemplo y probarla con su webcam se los agradeceria.
Hello everyone, today my current job leaves me some free time to review my sample apps.
VisionEngine became VisionEngineMT due to Multithreading (multithreading in the Zbar engine). Since Zbar is very old (dating from 2012), I decided to use ZXing, so I removed all traces of Zbar from the example.
Since I can't find my homebrew webcam (made from an old laptop), I decided to implement the ability to decode barcodes from images.
I would be grateful to anyone who would be kind enough to compile the example and test it with their webcam.
VisionEngineMT
Source Code:
VisionEngineMT.rar
(1.4 MiB) Downloaded 15 times
