Grid click
Grid click
Hello,
I have a GRID
   DEFINE GRID       GRID_GEN_ERRORS
      ROW            50
      COL            10
      WIDTH          1600
      HEIGHT         850
      HEADERS        {'ID', 'PERS', 'STATUS', 'ERROR-WARNING'  }
      WIDTHS         {1,   70,     100,      1400   }
      JUSTIFY        {GRID_JTFY_LEFT, GRID_JTFY_LEFT,GRID_JTFY_LEFT, GRID_JTFY_LEFT  }
      CELLNAVIGATION TRUE
      FONTSIZE       16
      FONTNAME       'Arial'
      FONTBOLD       TRUE
      COLUMNWHEN     {  {|| FALSE },  {|| FALSE },  {|| TRUE },   { || FALSE }  }
      COLUMNCONTROLS {   { 'TEXTBOX',  'CHARACTER'}, ;
                         { 'COMBOBOX',   {'OK', 'TO DO', 'IN BEHANDELING' ,'IGNORE'}     }, ;
                         { 'TEXTBOX',  'CHARACTER'} }
      ALLOWEDIT      TRUE
      ITEMS          {}
   END GRID
   //    ONDBLCLICK     EDIT_GEN_ERROR_PERS()
   //    ONCLICK        EDIT_GEN_ERROR_PERS()
Somebody knows hot to get my ID-value?
I can change third column with Combobox without a problem.
But I need to have the value of column 1 (ID) when I click or double-click on it.
I tried with This.CellRowIndex, This.CellColIndex, This.CellRow, This.CellCol but it don't give back a value.
I tried with my own function (which works fine with grids without COLUMNCONTROLS )
FUNCTION Column_Value( ControlName, ParentForm , nCol )
LOCAL aRet := {}
nCol := Iif( nCol == Nil .Or. nCol == 0 , 1 , nCol )
aRet := GetProperty (  ParentForm  , ControlName , 'Item' , GetProperty( ParentForm , ControlName , 'Value' ) )
RETURN( aRet [ nCol ] )
Re: Grid click
Hello Serge,
Thanks for your request :!:
Please try the following working example: :arrow:
#include "minigui.ch"
#define COL_CODE    1
#define COL_NAME    2
#define COL_PHONE   3
FUNCTION Main()
   LOCAL aData := { ;
      { "1001", "John Doe", "(555) 111-1111" }, ;
      { "1002", "Jane Smith", "(555) 222-2222" } }
   DEFINE WINDOW Main ;
      AT 0, 0 ;
      WIDTH 600 ;
      HEIGHT 400 ;
      TITLE "MiniGUI Grid Demo" ;
      MAIN
      @ 10, 10 GRID Grid1 ;
         WIDTH 580 ;
         HEIGHT 300 ;
         HEADERS { "Code", "Name", "Phone" } ;
         WIDTHS { 100, 200, 200 } ;
         ITEMS aData CELLNAVIGATION ;
         ON DBLCLICK MsgInfo( Main.Grid1.Cell(This.CellRowIndex, COL_CODE) )
      @ 320, 10 BUTTON BtnAdd CAPTION "Add Customer" ;
         ACTION AddCustomerRecord()
      @ 320, 110 BUTTON BtnUpdate CAPTION "Update Phone" ;
         ACTION UpdateCustomerPhone()
   Main.Center()
   Main.Activate()
PROCEDURE AddCustomerRecord()
   LOCAL aNewRecord, cLastCode, cNewCode
   IF Main.Grid1.ItemCount == 0
      MsgInfo("No records in the GRID. Adding the first record with code 1001.")
      cNewCode := "1001"
      cLastCode := Main.Grid1.Cell(Main.Grid1.ItemCount, COL_CODE)
      cNewCode := hb_ntos(Val(cLastCode) + 1)
   aNewRecord := { cNewCode, "New Customer", "(555) 555-5555" }
   Main.Grid1.DisableUpdate // Disable rendering for performance
   Main.Grid1.AddItem(aNewRecord)
   Main.Grid1.EnableUpdate  // Re-enable rendering
   Main.Grid1.Value := Main.Grid1.ItemCount
PROCEDURE UpdateCustomerPhone()
   LOCAL nSelectedRow, cNewPhone := "(555) 123-4567"
   nSelectedRow := Main.Grid1.Value[1]
   IF nSelectedRow == 0
      MsgInfo("No row selected!")
   IF !hb_RegexMatch("^\(?\d{3}\)?[-.\s]?\d{3}[-.\s]?\d{4}$", cNewPhone)
      MsgInfo("Invalid phone number format! Expected formats: (555) 555-5555 or 555-555-5555.")
   Main.Grid1.Cell(nSelectedRow, COL_PHONE) := cNewPhone
Hope this is helpful. 8-)
Re: Grid click
Thanks Grigory !
franco
Re: Grid click
Post by franco »
Hi Serge,
Could you use onheadclick().
I highlight the cell1 I want.
Then get cell 1`s value when I click header 1
All The Best,
Franco
Canada
Re: Grid click
Hi Franco, maybe you can supply a sample or piece of code?
Re: Grid click
Grigory,
I need grid like this: DOUBLECLICK +Column Edit...
         WIDTH 580 ;
         HEIGHT 300 ;
         ON DBLCLICK MsgInfo( Main.Grid1.Cell(This.CellRowIndex, COL_CODE) );
         COLUMNWHEN     {  {|| FALSE },  {|| FALSE },  {|| TRUE }  } ;
                            { 'TEXTBOX',  'CHARACTER'} } ;
         ALLOWEDIT   // gives syntax error !
I now have this working grid :
      ROW            50
      COL            10
      WIDTH          1600
      HEIGHT         850
      CELLNAVIGATION TRUE
      FONTSIZE       16
      FONTNAME       'Arial'
      FONTBOLD       TRUE
      ALLOWEDIT      TRUE
      ITEMS          {}
      ONCLICK        ToonID()
   END GRID
ONDBLCLICK doesn't work here but
ONCLICK works like double-click....! Very strange
Working only with DEFINE GRID and not with @ 50 ,10 GRID GRID_GEN_ERRORS ...
Greetings, Serge
franco
Re: Grid click
Post by franco »
Serge,
This is what I use.
ONHEADCLICK {  {|| MSGBOX('ID' },  {||'PERS'  },  {|| 'STATUS' },   { ||' ' }  }
OR YOURS
ONHEADCLICK {  {|| ToonID() },  {||' '  },  {|| ' ' },   { || ' ' }  }
With this you get the value of the selected cell. If I don`t want the value I put quotes like column 4.
Hope this helps.
When ALLOWEDIT is .T. on a double click you can edit. I think this is makes so double click won`t work for view.
All The Best,
Franco
Canada
franco
Re: Grid click
Post by franco »
I was just going over some of my sample code and ran across this I could be of use.
With this to edit you must hit enter key first. You could use any key like plus key chr(43)
COLUMNWHEN { {|| FALSE }, {|| FALSE }, ,{ || iIf(HMG_GetLastVirtualKeyDown() == 13, .T., .F.)}, { || FALSE } }
Or the plus key
COLUMNWHEN { {|| FALSE }, {|| FALSE }, ,{ || iIf(HMG_GetLastVirtualKeyDown() == 43, .T., .F.)} { || FALSE } }
All The Best,
Franco
Canada
Re: Grid click
Thanks Franco,
I now have it working:
      ROW            50
      COL            10
      WIDTH          1600
      HEIGHT         850
      CELLNAVIGATION TRUE
      FONTSIZE       16
      FONTNAME       'Arial'
      FONTBOLD       TRUE
                         { 'COMBOBOX',   {'OK', 'TO DO', 'BUSY' ,'IGNORE'}     }, ;
      ALLOWEDIT      TRUE
      ITEMS          {}
      ONCLICK        ToonID()
   END GRID
FUNCTION ToonID()
LOCAL cID
cID := GetCurrentID( "GRID_GEN_ERRORS", "Form_GEN_ERRORS" )
IF !EMPTY(cID)
   Form_GEN_ERRORS.TB_PERS_ID.Value := strvalue(cID)
FUNCTION GetCurrentID( cGrid, cForm )
lOCAL nRow
LOCAL aRow
nRow := GetProperty( cForm, cGrid, 'CellRowFocused' )
IF nRow <= 0
aRow := GetProperty( cForm, cGrid, 'Item', nRow )
RETURN aRow[2]  // pers_id
Now I can change 'STATUS' with Combobox and I can doubleclick on any cell (except STATUS) and then it gives me back
the ROW I clicked and I retrieve 2nd value from row which is the ID I need for other things.
franco
Re: Grid click
Post by franco »
Glad you got it working
I use head click on invoicing program.
if I hclick the qty header it will give me inventory on hand of item of of currenet selected row.
Hclick price will give cost of item
On a posted finalized invoice I use description to tell how the invoice was paid.
Saves a lot of time checking.
All The Best,
Franco
Canada
