variable Lost after Second Call
i have a funny Problem : i "lost" a Variable after Second Call ?
it work twice, but when call 3rd, Time i got "Error BASE/1003 Variable does not exist: DFROM" ???
i init it here
here i pass Parameter Image
and here i set Parameter as DEFAULT Image
here is the full Source CODE, look at BLPRESS.PRG
BLPRESS01.ZIP
(41.45 KiB) Downloaded 136 times
goto Main/Menu an select "Date Range" use one of the Radio Button (1-3, not 4)
try it again and when thy 3rd. Time you will get the Error ...
Re: variable Lost after Second Call
Jimmy, I will try this after Xmas!
S
found a Way to work : use Function instead of Variable !
*+ Source Module => x:\hmg.3.4.4\0\PULS\STACK.PRG
*+    Copyright(C) 1983-2026 by Auge & Ohr
*+    Functions: Function SP_INIT()
*+               Function SP_DFROM()
*+               Function SP_DTO()
*+    Reformatted by Click! 2.05.42 on Dec-25-2025 at  6:51 am
#xtranslate F_DFROM       => Stack\[SP, 1]
#xtranslate F_DTO         => Stack\[SP, 2]
STATIC Stack := {}
STATIC SP    := 0
*+    Function SP_INIT()
*+    Called from ( blpress.prg )   1 - procedure main()
FUNCTION SP_INIT()                                                    // init STACK
   AADD( Stack, ARRAY( 2 ) )
   SP ++
   F_DFROM := CTOD( " / / " )
   F_DTO := CTOD( " / / " )
*+    Called from ( blpress.prg )   1 - static procedure dosetrange()
*+                                   4 - static procedure dosetfilterrange()
FUNCTION SP_DFROM( Value )
   IF PCOUNT() > 0
      F_DFROM := Value
RETURN F_DFROM
FUNCTION SP_DTO( Value )
   IF PCOUNT() > 0
      F_DTO := Value
RETURN F_DTO
*+ EOF: STACK.PRG
PROCEDURE MAIN()
// on TOP
   SP_INIT()
STATIC PROCEDURE DoSetRange()
         ACTION { || nZEIT := DateFilter.RadioGroup_1.VALUE, ;
                  SP_DFROM( DateFilter.DatePicker_FROM.VALUE ), ;
                  SP_DTO( DateFilter.DatePicker_TO.VALUE ), ;
                  DoSetFilterRange( nZEIT ) }
STATIC PROCEDURE DoSetFilterRange( nZEIT )
LOCAL lUse   := USED()
LOCAL bError := ERRORBLOCK( { | oErr | BREAK( oErr ) } )
LOCAL oError
   BEGIN SEQUENCE
      SET FILTER TO
      BLPRESS.Text_Min.ReadOnly := .F.
      BLPRESS.Text_Max.ReadOnly := .F.
      IF SP_DTO() >= SP_DFROM()
         DO CASE
            CASE nZEIT = 3
               SET FILTER TO BLPRESS->PDATE >= SP_DFROM() .AND. ;
                             BLPRESS->PDATE <= SP_DTO()
            CASE nZEIT = 2
now it work as i like :)
franco
Post by franco »
Jimmy, your first program may have worked with PRIVATE variables for dates instead of local.
They stay active until you close the function/procedure that you create them in. Not sure about static procedure, have never used them.
All The Best,
Franco
Canada
franco wrote: Mon Dec 29, 2025 3:59 pm Jimmy, your first program may have worked with PRIVATE variables for dates instead of local.
THX for Answer.
i´m not sure if i have used PRIVATE for Test, i use PRIVATE only very rare.
Now using Function to store Value it work without Problem.
But i still don´t understand why it have crash before
i do not understand why it work Twice, but than Fail at 3rd Call ???
franco
Post by franco »
Jimmy, private variables stay active until you release calling program. Local are not available to any procedures called from
procedure making them.
Build this below. you will see how it works. in procedure checkvar variable "B" is known but "A" will crash as it was local only
to first Procedure or Function.
FUNCTION Main
local a:= 'ax'
private b := 'bx'
checkvar()
PROCEDURE checkvar()
msgbox(b)
msgbox(a)
All The Best,
Franco
Canada
franco wrote: Thu Jan 01, 2026 5:39 pm Build this below. you will see how it works. in procedure checkvar variable "B" is known but "A" will crash as it was local only to first Procedure or Function.
THX, i know this
as you can see i pass LOCAL as Parameter and i also declare DEFAULT TO so i don´t understand why a Error of "unkown DFROM" can exist ?!
p.s. i do not like using PRIVATE, because it becomes confusing with large programs containing many lines of CODE.
Using FUNCTION instead of PRIVATE/PUBLIC, together with a documenter like CLICK, you get an overview of WHERE the variables are called up.
franco
Post by franco »
Every time you go to a different function or procedure you will have to pass the parameter.
I use this all the time in very large programs, but never from a main type function. these functions get closed fairly quickly.
If I need variables for throughout the program I make them public. I also have a large control file that if I need to store variables
I have a field for them in there and can change them when needed.
I guess it depends on what you get used to doing..... We all have own ways.
All The Best,
Franco
Canada
