Title: Dbview (Editor xbase tables)
Compilation: © August-2026
Developer: Nélido Sánchez Alvarez, software developer
Translated by Google Translate
Summary:
Dbview is a tool to manage the structure and content of any table (xbase) giving the possibility
to delete all its content, insert-modify-delete rows or columns, repeat values ??from the previous
row, change the direction of the scroll when pressing enter, sort by one or more columns, search
for information, replace values, add data from another table or txt file and copy data to another
table or txt file optionally establishing conditions or filters. This application is very useful
for the development or update of new computer systems.
Dbview has allowed to perform the necessary operations on the tables of applications developed
in Windows 10 at 64 bits, without the need to install other much "heavier" tools on the PCs,
which use a greater amount of computer resources.
The Dbview application is freeware and is delivered with a free license for a period of 40 days
without copy restrictions of any kind. It can be installed automatically for 32 or 64 bits
depending on the type of OS installed on the PC.
Installing Dbview
1-Run DbviewSetup.exe
2-Associate any Xbase table with Dbview.exe of C:\Dbview folder
3-By License option extend the dbview license period (password required)
Título: Dbview (Editor de tablas xbase)
Compilación: © Agosto-2026
Desarrollador: Nélido Sánchez Alvarez, software developer
Traducido por el Tradutor de Google
Resumen:
El Dbview es una herramienta para gestionar la estructura y el contenido de cualquier tabla (xbase)
dando la posibilidad de borrar todo su contenido, insertar-modificar-eliminar filas o columnas,
repetir valores de la fila anterior, cambiar la dirección del desplazamiento al dar enter, ordenar
por una o varias columnas, hacer búsquedas de información, reemplazar valores, añadir datos desde
otra tabla o archivo txt y copiar datos hacia otra tabla o archivo txt estableciendo opcionalmente
condiciones o filtros. Esta aplicación es muy útil para el desarrollo o la actualización de nuevos
sistemas informáticos.
El Dbview ha permitido realizar las operaciones necesarias en las tablas de las aplicaciones
desarrolladas en Windows 10 a 64 bits, sin la necesidad de tener que instalar en las PC otras
herramientas mucho más "pesadas", que utilizan una mayor cantidad de recursos de las computadoras.
La aplicación Dbview es freeware y se entrega con una licencia gratis por un período de 40 días
sin restricciones de copia de ningún tipo. Se puede instalar automáticamente para 32 ó 64 bits
según el tipo de SO instalado en la PC.
Instalación del Dbview
1-Ejecutar el DbviewSetup.exe
2-Asociar cualquier tabla Xbase con el Dbview.exe de la carpeta c:\Dbview.exe
3-Por opción Licencia extender periodo de licencia del dbview (requiere contraseña)
https://drive.google.com/drive/folders/ ... Z6wCOabgCT
Editor de tablas xbase (es-en) para windows 32-64 bits
