HMG.EASY.SQL.2025.09.04
Changelog:
- New: Report(cQuery,cTitle,aHeaders,aWidths,aJustify,cPdfName,lPreview,aFormats) method.
Creates a PDF report from a MySql Query.
Returns: .T. if it was successful (.F. otherwise).
For PDF generation it uses a slightly modified version of the original HMG_HPDF by
Rathinagiri. I've renamed the source file and internal functions to avoid conflicts
with any other version of it.
Example:
	cCommand := 'SELECT code,description,location,stock,price FROM hmgtest ORDER BY code'
	cTitle	 := 'STOCK REPORT'
	aHeaders := { 'CODE', 'DESCRIPTION', 'LOCATION', 'STOCK', 'PRICE' }
	aWidths	 := { 6,32,32,6,12 }
	aJustify := { 'C','L', 'L','R','R'}
	cPdfName := 'stock' + '.' + dtos(date()) + '_' + alltrim(str(int(seconds())))
	lPreview := .t.
	aFormats := { {|x| STRZERO(x,4)},{|x|UPPER(x)},{|x|UPPER(x)},NIL,{|x|TRANSFORM(x,'999,999.99')} }
	IF !:Report(cCommand,cTitle,aHeaders,aWidths,aJustify,cPdfName,lPreview,aFormats)
- New: Export(cQuery,cOutFile,aFormats,cDelimiter,lQuote) method.
Creates a CSV file from a MySql Query.
Example:
		cQuery   := 'SELECT * FROM hmgtest ORDER BY code'
		cOutFile := 'hmgtest.csv'
		* aFormats (optional)
		aFormats := { {|x| STRZERO(x, 4)},{|x| STRZERO(x, 4)}, {|x| UPPER(x) },NIL,NIL,{|x| TRANSFORM(x,'999,999.99') } }
		* cDelimiter is optional (default is ';')
		cDelimiter := NIL
		* Quote is optional (default is .F.)
		lQuote := NIL
		IF !:Export(cQuery,cOutFile,aFormats,cDelimiter,lQuote)
I hope this be useful for someone.
hmg.easy.sql.2025.09.04.zip
(1.91 MiB) Downloaded 51 times
Steed
Re: HMG.EASY.SQL.2025.09.04
Post by Steed »
Thanks a a lot!,
Sorry to ask: but when i compilied the test , i have the next error
hbmk2: Error: Referenced, missing, but unknown function(s): SDDMY()
I'm using HMG 3.6.1
Copyright (c) 1999-2023, https://harbour.github.io/
C:/Ins/hmg/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/13.1.0/../../../../x86_64-w64-mingw32/bin/ld.exe: C:/Ins/hmg/lib-64\libhmg-64.a(h_HMG_HPDF.o):h_HMG_HPDF.c:(.text+0xe0): multiple definition of `HB_FUN_HMG_HPDF_PAGECOUNT'; C:/Users/st_ed/AppData/Local/Temp/hbmk_vdwn32.dir/main.o:main.c:(.text+0x4e0): first defined here
C:/Ins/hmg/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/13.1.0/../../../../x86_64-w64-mingw32/bin/ld.exe: C:/Ins/hmg/lib-64\libhmg-64.a(h_HMG_HPDF.o):h_HMG_HPDF.c:(.text+0x100): multiple definition of `HB_FUN_HMG_HPDF_PAGENO'; C:/Users/st_ed/AppData/Local/Temp/hbmk_vdwn32.dir/main.o:main.c:(.text+0x500): first defined here
C:/Ins/hmg/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/13.1.0/../../../../x86_64-w64-mingw32/bin/ld.exe: C:/Users/st_ed/AppData/Local/Temp/hbmk_vdwn32.dir/main.o:main.c:(.data+0x2330): undefined reference to `HB_FUN_SDDMY'
hbmk2[test]: Error: Running linker. 1
Steed
Post by Steed »
Steed wrote: Sat Oct 04, 2025 1:48 am Thanks a a lot!,
I'm using HMG 3.6.1
Finally add in the test.hbc file the next libraries
libs=libmysql
libs=hbsqldd
libs=sddmy
It´ts compile , but know I had this new error.
ES
Steed wrote: Wed Oct 08, 2025 2:42 am
I'm using HMG 3.6.1
libs=libmysql
libs=hbsqldd
libs=sddmy
ES
I'm not fully sure, but, maybe that libmysql.dll that I've included in the demo being not compatible with your setup. I've included it along with the compiled demo to allow users to test it 'out of the box'. You should replace by to one that work for you.
Regarding the problems with HMG_HPDF, I've already noticed fixed for the next release.
