Page 1 of 2
USE http://.......
Posted: Fri Aug 07, 2009 3:10 am
by fchirico
Español:
Una pregunta:
Se puede de alguna manera hacer algo como esto?
USE
http://pepe.com.ar
Yo necesito es acceder a una DBF que se encuentra en una carpeta publicada en internet.
Saludo, Fernando Chirico.
English:
One question:
You can somehow do something like this?
USE
http://pepe.com.ar
I need to access a DBF is that it is in a public folder on the internet.
Regards, Fernando Chirico.
Re: USE http://.......
Posted: Fri Aug 07, 2009 3:35 am
IMHO it is not possible directly. However, we can use oHTTP object to create a temporary dbf file from the internet folder.
I had uploaded for you a test dbf and dbt file. Urls are
http://www.rathinagiri.in/TEST.DBF &
http://www.rathinagiri.in/TEST.DBT
Try this.
LOCAL oHttp, cHtml, hQuery, aLink, oNode, oDoc, cUrl, cFile
// temp.dbf
cFile := "temp.dbf"
cUrl := "http://www.rathinagiri.in/TEST.DBF"
oUrl := tURL():New(cUrl)
oHttp:= TIpClientHttp():new( oUrl )
IF .NOT. oHttp:open()
msgstop("Connection error:", oHttp:lastErrorMessage())
return nil
IF oHttp:ReadToFile( cFile )
msginfo("File "+ cFile + " written.")
Posted: Fri Aug 07, 2009 12:04 pm
by fchirico
rathinagiri wrote:IMHO it is not possible directly. However, we can use oHTTP object to create a temporary dbf file from the internet folder.
Try this.
// temp.dbf
cFile := "temp.dbf"
return nil
Thank you!
* What library need to compile?
* If I need job in a Shared Mode, how can i open DBF file?
Regards and tahnk you, Fernando Chirico.
Posted: Fri Aug 07, 2009 4:28 pm
- No separate library is required. Official HMG libraries are enough. I think it is in socket library.
- Since the temp dbf file is a disk file, it can be shared like any other dbf file.
Posted: Fri Aug 07, 2009 5:18 pm
by fchirico
rathinagiri wrote:- No separate library is required. Official HMG libraries are enough. I think it is in socket library.
rathinagiri, thanks for everytihng.
But my questions is if i can open in shared mode:
Example, USE temp SHARED
How can i do it with "oHttp:open()"?
Posted: Fri Aug 07, 2009 9:24 pm
by Vanguarda
Hi friends,
Fernando, why don´t try with LetoDB?!
I think that would be more easy if you wanna share the database in real time.
with best regards,
Posted: Fri Aug 07, 2009 11:53 pm
by fchirico
Hi friends,
with best regards,
Of course.
That was the other possibility. But I always try to avoid libraries.
Thank you!
Posted: Sat Aug 08, 2009 12:08 am
by Vanguarda
Understood!
regards,
Posted: Sun Aug 09, 2009 6:57 pm
by ClaudioGalera
Hola a Todos
Opino que el problema no esta del lado del cliente, sino del lado del servidor, y por lo tanto lo que necesitamos es algo (un servidor) que nos provea el acceso a los registros de la base de datos, por eso opino lo mismo que Vanguarda, Letodb es una muy buena opcion.
Otra opcion es usar PHP para que lea el dbf y utilizar alguna rutina que nos lea la respuesta del servidor que contendra el registro que necesitamos.
Claudio
Google Translate
Hello All
I believe the problem is not client side but server side, and therefore we need something (a server) that give us access to records in the database, so I feel like Vanguarda, Letodb is a very good option.
Another option is to use PHP to read the dbf and use a routine that we read the response from the server that contains the record you need.
Greetings
Claudio
Posted: Mon Aug 10, 2009 6:48 am
by swapan
INTERESTING THREAD.................................
