button backcolor
franco
button backcolor
Post by franco »
I am trying to set the backcolor of a button.
Is this possible. I can do it with a label but setting the text of a label is harder.
Define Button button_1
Row 60
Col 135
Caption 'Hello'
BackColor {72,255,72}
End Button
Thanks in advance
All The Best,
Franco
Canada
Re: button backcolor
Franco,
According to the DOCS there is no backcolor for buttons...
franco
Post by franco »
Thanks Serge,
I am changing all my buttons to labels. It seems to work and gives my screens a brighter and more modern look.
Define Label button_1             //change
Row 60
Col 135
Value 'Hello'                           //change
End Label                               //change
This way references stay same as names are still button
All The Best,
Franco
Canada
I did the same!
jorge_riv
DBs Used: DBF, MySQL,SQL SERVER, Oracle.
Post by jorge_riv »
@ 10,Y BUTTONEX Bt_Exit WIDTH 139 HEIGHT 30 CAPTION "Exit" ;
ICON cImg FONTCOLOR BLACK SIZE 18 BOLD FLAT NOXPSTYLE ;
HANDCURSOR NOTABSTOP BACKCOLOR {{0.5,CLR_BLANCO, ;
CLR_NEGRO},{0.5,CLR_NEGRO,CLR_BLANCO}} GRADIENTFILL ;
{{0.5,CLR_ROJO,CLR_BLANCO},{0.5,CLR_BLANCO,CLR_ROJO}} ;
ON MOUSEHOVER ( This.Backcolor:=BLACK, ;
This.Fontcolor := WHITE,This.Icon := cIco, ;
This.ImageWidth := 45,This.ImageHeight := 45 ) ;
ON MOUSELEAVE ( This.Backcolor:=RED, ;
This.Fontcolor := BLACK,This.Icon := cImg, ;
ACTION (IF(Salida_Color(),ThisWindow.Release, ;
This.Setfocus))
c_aTip := InitToolTipEx( This.Bt_Exit.Handle,," ",'Salida', 2,;
hb_bitOr(TTS_BALLOON,TTS_NOFADE),TTF_SUBCLASS)
PD: el bottom esta programado en: Harbour MiniGUI Extended Edition 24.06 (Standard)
Labels work very fine, tou can use hover effect, you can also set alignment. i use them in a few of my applications. You can also set tabstop
franco
Post by franco »
Thanks Jorge,
This works good in minigui.
Is there a way to add minigui to hmg, I can not get it to work in hmg.
Like
#include <minigui.ch>
DEFINE BUTTONEX BUTTON_1
BACKCOLOR{168,0,0}
END BUTTONEX
All The Best,
Franco
Canada
I don't think it's possible to add buttoex to hmg in simple way
franco
Post by franco »
The label colors look so blaw, is there a way to living them up. Like dark edges and lighter in the middle.
All The Best,
Franco
Canada
Perhaps you can use a picture or some image?
