Posts: 2093 Joined: Sun Aug 25, 2019 3:12 pm
Post
by AUGE_OHR » Thu Oct 03, 2024 8:40 am
i got this Error,
Unrecoverable error 9201: hb_cdxPageSeekKey: wrong parent key.
Called from DBSEEK(0)
Called from SEEKKEYINPUT(2779) in HBTEL.PRG
Called from (b)MAIN(290) in HBTEL.PRG
Called from _HMG_GRIDONCLICKANDONKEYEVENT(703) in source\h_grid.prg
Called from EVENTPROCESS(283) in source\h_EventCB.prg
Called from DOMESSAGELOOP(0)
Called from _ACTIVATEWINDOW(6269) in source\h_windows.prg
Called from MAIN(404) in HBTEL.PRG
i have try to include Line 2778 but same Error
2776 IF USED()
2777 ORDSETFOCUS("KDNAME")
2778 cLocalSearchString := VAR2CHAR(cLocalSearchString) // => hb_valToExp()
2779 SEEK( UPPER( cLocalSearchString ) )
what does the Error want to tell me
Posts: 3309 Joined: Sun Nov 25, 2012 2:44 pm
DBs Used: 1 MySQL - MariaDB 2 DBF
Post
by serge_girard » Thu Oct 03, 2024 12:02 pm
what INDEX?
Post
by AUGE_OHR » Thu Oct 03, 2024 12:31 pm
hi Serge,
*.CDX create by Xbase++
PROCEDURE CreateCDX( cCodepage )
LOCAL _tagname, _keyfeld, _cdxname
USE XPPTEL.DBF VIA "DBFCDX" EXCLUSIVE CODEPAGE (cCodepage)
_cdxname := "XPPTEL.CDX" // "TELINDEX"
_tagname := "KDNAME" //zkdname 1
_KEYFELD := "UPPER(NAME1+NAME2)"
ORDCREATE( _cdxname, _tagname, _keyfeld )
CLOSE INDEX
// 12 more TAGs
Post
by serge_girard » Thu Oct 03, 2024 12:49 pm
and what is value of : cLocalSearchString := VAR2CHAR(cLocalSearchString)
before and after?
Post
by AUGE_OHR » Thu Oct 03, 2024 9:59 pm
hi Serge,
serge_girard wrote: ↑ Thu Oct 03, 2024 12:49 pm
before and after?
her i start within a GRID by press a Alpha-Key (a-z)
DEFINE GRID Browse_1
ON KEY SeekKeyInput()
END GRID
her the full CODE
2750 STATIC FUNCTION SeekKeyInput()
2751
2752 LOCAL cInkey := ""
2753 LOCAL ch, i, k, cLocalSearchString
2754
2755 // ch := HMG_GetLastCharacter()
2756 ch := HMG_GetLastCharacterEx()
2757
2758 IF HMG_GetLastVirtualKeyDown() == VK_BACK // backspace
2759 HMG_CleanLastVirtualKeyDown()
2760 cSearchString := HB_ULEFT( cSearchString, MAX( 0, HMG_LEN( cSearchString ) - 1 ) )
2761 cLocalSearchString := cSearchString
2762
2763 ELSEIF HMG_GetLastVirtualKeyDown() == VK_ESCAPE //
2764 HMG_CleanLastVirtualKeyDown()
2765 cSearchString := ""
2767 SetProperty( "XPPTEL", "Text_Suche", "Value", cSearchString )
2768 RETURN Nil // enable processing the current message
2769
2770 ELSE
2771 IF EventMsg() <> WM_CHAR
2772 RETURN Nil // enable processing the current message
2773 ENDIF
2774 cLocalSearchString := cSearchString + ch
2775 ENDIF
2776
2777 IF USED()
2778 ORDSETFOCUS("KDNAME")
2779 cLocalSearchString := VAR2CHAR(cLocalSearchString)
2780 SEEK( UPPER( cLocalSearchString ) )
i have add line 2779 only to be sure that i search using a String (VAR2CHAR() -> hb_valToExp() )
Post
by serge_girard » Fri Oct 04, 2024 7:49 am
Strange.. try with LOCATE
Posts: 999 Joined: Thu Oct 16, 2014 11:35 am
Post
by edk » Fri Oct 04, 2024 1:52 pm
My guess is that the API works in CP UTF8, and what CP is DBF in? Perhaps there is a conversion problem between CPs?
