How to build DBF > 2 GB
i know that harbour can use DBF > 2 GB under 64 Bit using DB_DBFLOCK_HB64
but how to create a DBF > 2 GB ?
Re: How to build DBF > 2 GB
thx for the Link.
but how to setup DBF to use DB_DBFLOCK_HB64
i´m not able to create a DBF to use more than 2 GB
This code below creates a dbf file over 4 GB in size, I set the locking scheme to DB_DBFLOCK_HB64 and did not notice any problems with accessing the records. I compiled in 64 bits using hmg 3.6.
#include "dbinfo.ch"
proc main()
local i, n := int(2^22) + 10, nStep := int ( n / 50 ), cF1, nId, nRow, nCol
   SET DBFLOCKSCHEME TO DB_DBFLOCK_HB64
   if !file("tst4GB.dbf")
      ? "Building tst4GB.dbf..., be patient ..."
      ? REPLICATE ( Chr ( 177 ), 50 )
      DevPos( ROW(), COL()-50 )
      dbcreate("tst4GB.dbf",{{"F1","C",1023,0}, {"id","+",4,0}})
      use tst4GB exclusive
      for i:=1 to n
         dbappend()
         replace F1 with str(i,10)
         IF i%nStep = 0
	      ?? Chr ( 219 )
      next i
      close
      ?? " 100% done"
   use tst4GB shared alias tst1 new
   use tst4GB shared alias tst2 new
   ? "records:", tst1->(lastrec()), ;
      ", size:", tst1->(header())+tst1->(lastrec())*tst1->(recsize())
   ? "Alias tst1 goto:", lastrec(), tst1->(dbgoto(lastrec()))
   ? "Alias tst1 recno():", tst1->(recno()), "->", alltrim(tst1->(fieldget(1))), "->" , tst1->(fieldget(2))
   ? "Alias tst2 goto:", lastrec(), tst2->(dbgoto(lastrec()))
   ? "Alias tst2 recno():", tst2->(recno()), "->", alltrim(tst2->(fieldget(1))), "->" , tst2->(fieldget(2))
   ? "Alias tst1 FLOCK: ", tst1->(flock())
   ? "Testing reading of alias tst2 records when the file is locked in alias tst1 ..."
   for i:=1 to n
	tst2->(dbgoto(i))
        cF1 := alltrim(tst2->(fieldget(1)))
	nId := tst2->(fieldget(2))
        IF i%nStep = 0
	    ?? Chr ( 219 )
	    nCol := Col()
            nRow := Row()
            ? "RecNo:", tst2->(recno()), "F1:", cF1, "Id:", nId
	    DevPos( nRow, nCol )
   next i
   ?? " 100% done"
   ? "Press any key to exit ..."
   close all
   inkey ( 0 )
return
hi Edward,
you are absolute right.
i was not aware that Field Type C can have more than 256 length under Harbour 64 BIt
Thx for your Demo to make it clear to me
The code below shows what effect the choice of locking scheme has when working with large DBF files:
REQUEST HB_GT_WIN_DEFAULT
proc main()
   ErrorBlock( { | oError | NewError( oError ) } )
   ? "DBF lock scheme is DB_DBFLOCK_HB64."
      for i:=1 to n
         dbappend()
         IF i%nStep = 0
	      ?? Chr ( 219 )
      next i
      close
      ?? " 100% done"
   MakeTest ( n, nStep )
   tst1->(dbUnlock())
   close all
   ? "DBF lock scheme is default."
   ? "Same test with default DBF lock scheme ..."
   close all
   inkey ( 0 )
return
Function MakeTest ( n, nStep )
Local i, cF1, nId, nRow, nCol
nCol := Col()
nRow := Row()
for i:=1 to n
    tst2->(dbgoto(i))
    if i%nStep = 0
        ?? Chr ( 219 )
        nCol := Col()
        nRow := Row()
next i
?? " 100% done"
RETURN Nil
FUNCTION NewError( oError )
   LOCAL cMessage
   LOCAL n
   #include "error.ch"
   #INCLUDE "COMMON.CH"
   // By default, division by zero results in zero
   IF oError:genCode == EG_ZERODIV
      RETURN 0
   // Set NetErr() of there was a database open error
   IF oError:genCode == EG_OPEN .AND. ;
      oError:osCode == 32 .AND. ;
      oError:canDefault
      NetErr( .T. )
      RETURN .F.
   // Set NetErr() if there was a lock error on dbAppend()
   IF oError:genCode == EG_APPENDLOCK .AND. ;
      oError:canDefault
      NetErr( .T. )
      RETURN .F.
   cMessage := ErrorMessage( oError )
   IF ! Empty( oError:osCode )
      cMessage += " " + "(DOS Error " + LTRIM( STR( oError:osCode ) ) + ")"
   n := 2
   cMessage += CHR(13) + CHR (10) + CHR(13) + CHR (10)
   WHILE ! Empty( ProcName( n ) )
      cMessage += "Called from " + ProcName( n ) + "(" + ALLTRIM( STR( ProcLine( n++ ) ) ) + ")" +CHR(13) +CHR(10)
   ENDDO
   ? cMessage
   ? "Press any key..."
   inkey ( 0 )
   quit
   RETURN .F.
STATIC FUNCTION ErrorMessage( oError )
   LOCAL cMessage, n
   // start error message
   cMessage := iif( oError:severity > ES_WARNING, "Error", "Warning" ) + " "
   // add subsystem name if available
   IF ISCHARACTER( oError:subsystem )
      cMessage += oError:subsystem()
      cMessage += "???"
   // add subsystem's error code if available
   IF ISNUMBER( oError:subCode )
      cMessage += "/" + LTRIM( STR( oError:subCode ) )
      cMessage += "/???"
   // add error description if available
   IF ISCHARACTER( oError:description )
      cMessage += "  " + oError:description
   // add either filename or operation
   IF !Empty( oError:filename )
      cMessage += ": " + oError:filename  + CHR( 13 ) + CHR( 10 )
   IF !Empty( oError:operation )
      cMessage += ": " + oError:operation + CHR( 13 ) + CHR( 10 )
   // add oError:Args
   if ValType( oError:Args ) == "A"
       cMessage += "   Arguments   :" + CHR( 13 ) + CHR( 10 )
       FOR n = 1 to Len( oError:Args )
           cMessage += "     [" + Str( n, 4 ) + "] = " + ValType( oError:Args[ n ] ) + ;
                        "   " + hb_valToExp( oError:Args[ n ] ) + CHR( 13 ) + CHR( 10 )
   IF !Empty ( Alias () )
   	cMessage += "   Alias: " + Alias()
   RETURN cMessage
