HMG Extended Edition version 24.06 is published
Hi Friends,
The MiniGUI team is pleased to announce the release of the latest version of Harbour MiniGUI Extended Edition.
The installation file of the free STANDARD build for Borland C++ 5.8.2 is published at:
https://hmgextended.com/files/CONTRIB/h ... -setup.exe
Note. This build contains a debug version of the MiniGUI library.
A password-protected 7z archive of the PROFESSIONAL build for Borland C++ 5.8.2 can be downloaded from:
https://hmgextended.com/files/CONTRIB/hmg-24.06-pro.7z
NB. The password for Pro build 24.05 will also work for Pro build 24.06.
Upgrading to this build is highly recommended (and this is very important for all TBrowse users due to the resource leak fix).
Many thanks to all donors for supporting this project.
Best wishes,
[MiniGUI Team]
Re: HMG Extended Edition version 24.06 is published
Hi Friends,
Please notice that there are also the private MiniGUI builds
for the MinGW C-compiler (32-bit and 64-bit):
MinGW GNU C 14.1.0 (packaged on 2024-05-08).
                Components versions:
Harbour MiniGUI Extended Edition 24.06 (PRO)
Harbour 3.2.0dev (r2405310955)
Harbour Make (hbmk2) 3.2.0dev (r2024-05-31 09:55)
There is also a MiniGUI package for the latest BCC 7.70 (32-bit):
Harbour 3.2.0dev (r2405130039)
Harbour Make (hbmk2) 3.2.0dev (r2024-05-13 00:39)
Embarcadero C++ 7.70 for Win32 Copyright (c) 1993-2023 Embarcadero Technologies, Inc.
NEW! I've already prepared a MiniGUI package for the latest BCC 7.70 (64-bit):
Embarcadero C++ 7.70 for Win64 Copyright (c) 2012-2023 Embarcadero Technologies, Inc.
The above distributions have the updated SQLRDD library and MySQL server support
(using the example of "MySql Client"), and they are available to all donors.
Thanks for your attention.
Hi there,
There is good news for now. :)
I've successfully tested the MINGW 15.0 snapshot with the newest MiniGUI build (64-bit).
Please look at the images below:
Your feedback is welcome. :arrow:
Thanks Grigory !
