Hi Friends,
The MiniGUI team is pleased to announce the release of the latest version of Harbour MiniGUI Extended Edition.
The installation file of the free STANDARD build for Borland C++ 5.8.2 is published at:
https://hmgextended.com/files/CONTRIB/h ... -setup.exe
Note. This build contains a debug version of the MiniGUI library.
A password-protected 7z archive of the PROFESSIONAL build for Borland C++ 5.8.2 can be downloaded from:
https://hmgextended.com/files/CONTRIB/hmg-24.05-pro.7z
NB. This build includes the xBase Package 2024 applications source code created by Marcelo Neves.
The three-month promotion for the PRO version has ended and now costs $50.
Upgrading to this build is recommended.
Many thanks to all donors for supporting this project.
Best wishes,
[MiniGUI Team]
HMG Extended Edition version 24.05 is published
Re: HMG Extended Edition version 24.05 is published
Hi Friends,
Please notice that there are also the private MiniGUI builds
for the MinGW C-compiler (32-bit and 64-bit):
MinGW GNU C 14.1.0 (packaged on 2024-05-08).
There is also a MiniGUI package for the latest BCC 7.70 (32-bit):
The above distributions have the updated SQLRDD library and MySQL server support
(using the example of "MySql Client"), and they are available to all donors.
Thanks for your attention.
Components versions:
Harbour MiniGUI Extended Edition 24.05 (Release)
Harbour 3.2.0dev (r2405092123)
Harbour Make (hbmk2) 3.2.0dev (r2024-05-09 21:23)
Harbour 3.2.0dev (r2402161723)
Harbour Make (hbmk2) 3.2.0dev (r2024-02-16 17:23)
Embarcadero C++ 7.70 for Win32 Copyright (c) 1993-2023 Embarcadero Technologies, Inc.
Thanks !
