How to return the pre-processed version of a command?
Posted: Thu May 02, 2024 10:42 pm
by HGAutomator
Programmatically, how do I get back the functional (i.e. pre-processed) version of a command?
I tried using e.g.
p_p := __pp_Init()
Command_s := "SET MARGIN TO"
Preprocessed_s := __pp_Process( p_p, Command_s )
, which I thought should return
Set( _SET_MARGIN, 0 )
, but it just returns the original command.
Maybe I'm setting it up wrong.
Re: How to return the pre-processed version of a command?
Posted: Fri May 03, 2024 8:36 am
by gfilatov
HGAutomator wrote: Thu May 02, 2024 10:42 pm Hi,
Please add the following line on top of your test program:
REQUEST __pp_StdRules
You can look at the following working example:
REQUEST HB_GT_WIN_DEFAULT
PROCEDURE Main()
   LOCAL cString
   LOCAL pPP := __pp_Init()
   CLS
   ? "Testing Harbour run-time preprocessing"
   ? cString := "@ 10, 10 SAY 'Hello!'"
   ? __pp_Process( pPP, cString )
   ? cString := "? 'Hello mom'"
   ? cString := "SET MARGIN TO Something"
   WAIT
Program output is below: :arrow:
Hope this is helpful. :idea:
Posted: Fri May 03, 2024 1:12 pm
by HGAutomator
That did the trick, thanks Grigory.
Posted: Fri May 03, 2024 8:57 pm
by HGAutomator
Everything is working perfectly, much appreciated.
Do you know how we would preprocess non-standard custom commands defined in other .ch files?
