HMG Extended Edition version 24.04 is published
Hi Friends,
The MiniGUI team is pleased to announce the release of the latest version of Harbour MiniGUI Extended Edition.
Here's a breakdown of some of the modifications in the build 24.04.
* Fixed: Program crash at the exit from a Preview window in a graph printing
module at using of xHarbour compiler (introduced in the build 17.06).
* Fixed: Problem with button's focus at a window activation when this button
was defined with the DEFAULT clause (introduced in the build 18.11).
* Modified: MiniGUI core has been updated for correct compiling with the new
Pelles C 12.0 and xHarbour compiler.
* Updated: Header file i_pseudofunc.ch for compatibility with xHarbour.
* Updated: hbmk2 utility is thread-aware during compilation in MT mode.
(see source code in folder \harbour\utils\hbmk2) [PRO VERSION]
* New: 'C source code reformatter GreatCode' utility by Christophe Beaudet
(see in folder \Utils\GreatCode) [PRO VERSION]
* Updated the TSBrowse, hbVpdf, HMG_HPDF and SQLite3 libraries.
* Updated some Basic and Advanced samples.
The installation file for the standard build of Borland C++ 5.8.2 is published at:
https://hmgextended.com/files/CONTRIB/h ... -setup.exe
A password-protected 7z archive of the professional build for Borland C++ 5.8.2 is published at:
https://hmgextended.com/files/CONTRIB/hmg-24.04-pro.7z
The PRO version password is available only to donors.
Upgrading to this build is recommended.
I wish everyone to enjoy programming in HMG.
Best wishes,
[MiniGUI Team]
Re: HMG Extended Edition version 24.04 is published
Hi Friends,
Please notice that there are also the private MiniGUI builds
for the MinGW C-compiler (32-bit and 64-bit):
MinGW GNU C 13.2.0 (packaged on 2024-04-12). ;)
                Components versions:
Harbour MiniGUI Extended Edition 24.04 (Release)
Harbour 3.2.0dev (r2403071241)
Harbour Make (hbmk2) 3.2.0dev (r2024-03-07 12:41)
The above distributions have the updated SQLRDD library and MySQL server support
(using the example of "MySql Client"), and they are available to all donors.
Thanks for your attention. 8-)
Thanks Grigory !
