HMG Extended Edition version 24.03 is published
Hi Friends,
The MiniGUI team is pleased to announce the release of the latest version of Harbour MiniGUI Extended Edition.
The installation file for the standard build of Borland C++ 5.8.2 is published at:
https://hmgextended.com/files/CONTRIB/h ... -setup.exe
A password-protected 7z archive of the professional build for Borland C++ 5.8.2 is published at:
https://hmgextended.com/files/CONTRIB/hmg-24.03-pro.7z
The PRO version password is available only to donors.
Upgrading to this build is recommended.
I wish everyone to enjoy programming in HMG.
Best wishes,
[MiniGUI Team]
Best wishes,
[MiniGUI Team]
Re: HMG Extended Edition version 24.03 is published
Hi Friends,
Please notice that there are also the private MiniGUI builds
for the MinGW C-compiler (32-bit and 64-bit):
MinGW GNU C 13.2.0 (packaged on 2024-03-10).
Components versions:
Harbour MiniGUI Extended Edition 24.03 (Release)
Harbour 3.2.0dev (r2403071241)
Harbour Make (hbmk2) 3.2.0dev (r2024-03-07 12:41)
The above distributions have the updated SQLRDD library and MySQL server support
(using the example of УMySql ClientФ), and they are available to all donors.
Thanks for your attention.
Greetings,
Grigory
Greetings,
Grigory
Thanks !
Hi Serge,
How are you doing
Thank you for your continued attention and feedback
Hi Grigory,
I'm fine and yesterday I coincidentally passed at Luyksgestel and was thinking of our meeting two years ago ! We made this photo!
Still in Luyksgestel?
- grigory and serge.jpg (46.43 KiB) Viewed 11585 times
Hi Serge,serge_girard wrote: ↑Tue Mar 19, 2024 4:10 pm Hi Grigory,
Thank you for reminding
Yes, I'm still here.
See you soon
Hi Friends,
I have prepared a comparison of standard and professional builds of MiniGUI in the form of a table below:
Hoping this will be helpful
Compiler: Borland C++ 5.8.2 (32-bit)
| | STANDARD | PRO-build |
| Harbour binary | Standard | Optimized |
| MiniGUI library | Debug | Release |
| Hmgs-Ide binary | Supported | Supported |
| HMG IDE binary and source | - | Supported |
| Basic samples | Supported | Supported |
| Advanced samples | Supported | Supported |
| Applications samples | - | Supported |
| Utils samples | - | Supported |
| SQLRDD library and samples| - | Supported |
Thanks !
Muchas Gracias.
