Ayuda con IPadrress
martingz
Ayuda con IPadrress
Post by martingz »
Estoy trabajando por primera vez con el control ipadrress, cuando inicio el control todo bien, pero si trato de ingresar una direccion solo me permite 2 digitos de los 3 que necesito, anexo un ejemplo
Agradezco de antemano culquier apoyo
I am working for the first time with the ipadress control, when I start the control everything is fine, but if I try to enter an address it only allows me 2 digits of the 3 that I need, I attach an example
I thank you in advance for any support
Re: Ayuda con IPadrress
Martingz,
Can you please supply source?
S
serge_girard wrote: Sat Mar 16, 2024 7:37 am Martingz,
S
Hello Martingz,
I confirm this strange behavior of the sample in the folder
c:\hmg.3.4.4\SAMPLES\Controls\IPAddress\IPADDRESS_1
Thanks for your bug report :!:
BTW IPADDRESS control works fine in the MiniGUI Ex 8-)
martingz
Post by martingz »
Serge is ipadress demo both demos
Thanks for you
OK, never used it !
martingz
Post by martingz »
Thank you Grigory for your support
martingz
Post by martingz »
I left the topic for a bit to clear my head and today I continued with the tests. Everything is fine with the control, except that the default length of the control does not allow you to see or change the 3 digits, it is only an increase of 120 from the default at 140 and it lets us see all the digits
I'm leaving this here in case anyone has the same problem.
Greetings and thanks for your support
