A FORM has a PICTURE Control.
This PICTURE Control's ACTION Event calls a Function.
When a mouse click happens on the PICTURE Control I need to save its location.
My Question:
How can this Function determine the click's row and column (on the PICTURE image)?
Thank you for your kind guidance here.
Red2
Location of a Mouse click on a PICTURE control?
Red2
Re: Location of a Mouse click on a PICTURE control?
Hello All,
I have been searching for some way to locate a mouse click's location on a PICTURE control.
I found two possible candidates:
Also I cannot find a definition of what they return.
These might be helpful in calculating the mouse click's location on the PICTURE.
Would someone more advanced point me to a definition?
Thanks again!
Unfortunately these values do not directly indicate where the PICTURE was clicked.lnRow := _HMG_SYSDATA[ 191 ]
lnCol := _HMG_SYSDATA[ 192 ]
lnCursRow := GetCursorRow()
lnCursCol := GetCursorCol()
Thanks again!
Hello Spencer,Red2 wrote: ↑Tue Feb 20, 2024 11:58 pm Hello All,
I found two possible candidates:Unfortunately these values do not directly indicate where the PICTURE was clicked.lnRow := _HMG_SYSDATA[ 191 ]
Thanks again!
Thanks for your interest.
You can find the source code for working example along with the executable in the attachment below.
But the above code is for use with MiniGUI Extended Edition.
Look at the following code snippet with a hint:
FUNCTION Determine_The_Portion_Of_The_Picture( aPoint )
STATIC s_aImage := { { 0, 0, 200, 149 }, { 202, 0, 691, 149 }, { 693, 0, 933, 149 } }
LOCAL nArea
LOCAL cMsg := ""
IF ( nArea := Ascan( s_aImage, { |aRect| PtInRect( aPoint, aRect ) } ) ) > 0
cMsg += "Pos Y: " + hb_NtoS( aPoint[ 2 ] ) + "; "
cMsg += "Pos X: " + hb_NtoS( aPoint[ 1 ] )
cMsg += CRLF + CRLF + "Area #" + hb_NtoS( nArea )
cMsg += CRLF + "Part " + hb_NtoS( nArea ) + " of a picture."
RETURN cMsg
- TrackingToolTips.zip
- (928.76 KiB) Downloaded 68 times
- vagblad
- DBs Used: MySQL,DBF
Hello Red,
I'll add my own implementation of the matter at hand fo a similar situation(not exactly like the one you described)!!!It is definitely not as clean as the one that Grigory posted but i thought it might help someone.
So i wanted to hover over a control and then when i press a key combination to select that control.
aControls is an array which includes the following elements:
You can replace the GetCursorPos() function with the ones you used:
So in the end you get an array with the name of the control,row,column etc. The control you've hovered over.
Hope it helps
aCoords := GetCursorPos()
If !Empty(aCoords)
For i := 1 to len(aControls)
nMinX := aControls[i][6] + nFormCol//The column of the control + the column of the form
nMaxX := aControls[i][6] + aControls[i][4] + nFormCol //The last pixel of the control on X Axis(control's column + control's width)
nMinY := aControls[i][7] + nFormRow//The row of the control + the row of the form
nMaxY := aControls[i][7] + aControls[i][5] + nFormRow//The last pixel of the control on Y Axis(control's row + control's height)
If aCoords[1] >= nMinY .AND. aCoords[1] <= nMaxY //If the cursor is in between the limits of the Y axis
If aCoords[2] >= nMinX .AND. aCoords[2] <= nMaxX //If the cursor is also in between the limits of the X axis
If aControls[i][8] == .T. //If the control which is on the cursor is visible
AAdd(aMatchControls, aControls[i])
EndIf
EndIf
EndIf
Next i
EndIf
aControls[i][6] := GetProperty(cForm,cControl,"Col")
aControls[i][7] := GetProperty(cForm,cControl,"Row")
aControls[i][8] := GetProperty(cForm,cControl,"Visible")lnCursRow := GetCursorRow()
Hope it helps
Vagelis Prodromidis
