HMG Extended Edition version 24.01 is published
Hi Friends,
We are pleased to announce the latest build of Harbour MiniGUI Extended Edition.
A setup of the ANSI build 24.01 for Borland C++ 5.8.2 is published at the following URL:
https://hmgextended.com/files/CONTRIB/h ... -setup.exe
(SHA-256: 8d506a1c284bb8cbc6ba3f1298a6a806585ee9a718e560113111e8998b91324e)
and an alternative link to the zip archive (if your browser refuses to download EXEs):
https://hmgextended.com/files/CONTRIB/h ... -setup.zip
(SHA-256: 3f40d354e2e7247c670f45bba4f55096e9823468f22f30d5c86b0f6e0f84e67c)
Upgrading to this build is recommended.
I wish everyone to enjoy programming in HMG.
Best wishes,
[MiniGUI Team]
Re: HMG Extended Edition version 24.01 is published
Please notice that there are also the private MiniGUI builds
for the MinGW C-compiler (32-bit and 64-bit):
MinGW GNU C 13.2.0 (packaged on 2023-12-26). :arrow:
Components versions:
Harbour MiniGUI Extended Edition 24.01 (Release)
Harbour 3.2.0dev (r2312082217)
Harbour Make (hbmk2) 3.2.0dev (r2023-12-08 22:17)
The above distributions have the SQLRDD library and MySQL server support
(using the example of "MySql Client"), and they are available to all donors.
Thanks for your attention. :)
Thanks Grigory !
ASESORMIX
Post by ASESORMIX »
Gracias Sr Grigory.
Hi guys!
Can somebody tell me if TSBrowse from HMG Ext. Ed. is better for browsing arrays than grid control from HMG official?
mol wrote: Tue Jan 23, 2024 9:16 pm Hi guys!
Hi Marek,
Thanks for your interest :!:
Look at the following image using a multi-line header, footer and progress bar when viewing an array:
You should choose for yourself. :arrow:
It really looks great, but I have no time to port myain application to hmg Extended. It would be great to adapt tsbrowse to hmg official.
You put some years ago tsbrowse module for hmg official, but I can't find it now
Post by EduardoLuis »
Grigory, EXCELLENT job.-
This tsbrowse looks like codejock browse.- I must agree with Mol, because i ve try many ways to compile my app with Hmg Ext, but, allways i fail.-
So till now, im using HMG 3.4.- A good idea will be performing an IDE that automatically generates the .EXE final file (like in HMG).- I know that making that proposal is very heavy, but in some time it will be the best of the best.-
Again, congratulations for your new version.-
With regards.-
Pcmodula
Post by Pcmodula »
EduardoLuis wrote: Wed Jan 24, 2024 7:28 pm Grigory, EXCELLENT job.-
With regards.-
Hi all,
Minigui Extended provide almost two ide and is full source included.
If you really wants use Minigui Extended and we need a powefull ide , I suggest use Designer:
https://github.com/ivanilmarcelino/designer
This tool include an updated Minigui distro :o , Borland compiler, mysql portable ,text editor, One terminal for function test, multilingual and one wonderfull ide . But i don't want say all features. ;)
Good programming with Minigui Extended.
