Hello All,
I want to rebuild the ANSI Debugger using HMG's .BAT file:
Unfortunately, it generates the following error for me:
Build Library: ANSI
ERROR: file (INCLUDE\_ANSI.ch) not exist or failed copy
Press any key to continue . . .
However, ...INCLUDE\_ANSI.ch exists on my drive:
I am out of ideas. I would greatly appreciate any help.
Thank you!
Error rebuilding the Debugger
- AUGE_OHR
Re: Error rebuilding the Debugger
hi Red,
i don´t know where your Error come from.
does it work when switch to Unicode
in _ANSI.CH there is "nothing" so you do not need it when build ANSI App
Red2
Thank you Jimmy,
Unfortunately Unicode gives me a similar error message:
Build Library: UNICODE
ERROR: file (INCLUDE\_UNICODE.ch) not exist or failed copy
I recall that sometime back you make a simple but useful change to the debugger.
Do you now recall how you compiled it?
Thanks, I really appreciate your kind help!
- AUGE_OHR
hi Red,
Debugger was build using BuildLib32.bat / BuildLib64.bat which call hmg32.hbp / hmg64.hbp
