_HMG_SYSDATA
Red2
_HMG_SYSDATA
Post by Red2 »
Hello,
I often come across "_HMG_SYSDATA" references in HMG program code.
Occasionally I have guessed what values are and used them. (Only occasionally).
Today I found some minimal information in "C:\HMG.3.4.4\Source\h_windows.prg".
Unfortunately this falls short of great documentation.
Currently I need better detailed information.
Question:
Can you more experienced in HMG point me to any better documentation or explanations?
Google Translation:
A menudo me encuentro con referencias "_HMG_SYSDATA" en el código del programa HMG.
De vez en cuando he adivinado qué son los valores y los he usado. (Sólo de vez en cuando).
Hoy encontré información mínima en "C:\HMG.3.4.4\Source\h_windows.prg".
Desafortunadamente, esto no llega a ser una excelente documentación.
Actualmente necesito información mejor detallada.
Pregunta:
¿Puede usted, con más experiencia en HMG, indicarme una mejor documentación o explicaciones?
Thank you all for your kind guidance!
Re: _HMG_SYSDATA
hi Red,
you can compare HMG Source and Extended Version where _HMG_SYSDATA under HMG is (almost) the same like Member (DATA) of Extended Version
Red2
Re: _HMG_SYSDATA
Post by Red2 »
Thank you Jimmy,
I am looking underneath the MiniGui, "Extended Version", folder.
Unfortunately I do not quite understand, in this context, what "Member (DATA)" refers to.
Could you point me to specific files or examples?
Thank again!
Re: _HMG_SYSDATA
hi Red,
sorry, i forgot it are no CLASS CODE where i have DATA
under MiniGUI Extended Version you got _HMG_aControl??? instead of _HMG_SYSDATA [???]
for ??? MiniGUI Extended Version use a Name so you get a Idea what it is for
search for Variable and look where it store in Array
this will work up to _HMG_SYSDATA [40] of each Control
also look into INCLUDE\i_altsyntax.ch where you can find some Comment
Red2
Re: _HMG_SYSDATA
Post by Red2 »
Thank you very much Jimmy.
I will check this out.
Thanks again!
