HMG Extended Edition version 23.10 is published
Hi Friends,
We are pleased to announce the latest build of Harbour MiniGUI Extended
Edition.
A setup of the ANSI build 23.10 for Borland C++ 5.8.2 is published at
the following URL:
https://hmgextended.com/files/CONTRIB/h ... -setup.exe
There is also the MiniGUI build 23.10 for the xHarbour 1.3.0 compiler
(Build 20230914) and the latest BCC 7.60 for Win32 from the following link:
http://xharbour.org/index.asp?page=down ... naries_win
which is available upon your request.
Upgrading to this build is recommended.
I wish everyone to enjoy programming in HMG.
Best wishes,
[MiniGUI Team]
Re: HMG Extended Edition version 23.10 is published
Hi Friends,
Please notice that there are also the private MiniGUI builds
for the MinGW C-compiler (32-bit and 64-bit):
MinGW GNU C 13.2.0 (packaged on 2023-08-09).
The above distributions have the SQLRDD library and MySQL server support
(based on the example "MySql Client"), and they are available to all donors.
Thanks for your attention.
Greetings,
Grigory
Thanks Grigory !
franco
Post by franco »
Thank you.
All The Best,
Franco
Canada
Steed
Post by Steed »
Tks
Just to give you the latest news. :arrow:
These packages were compiled with GCC 13.2.0, packaged November 1, 2023.
ASESORMIX
Post by ASESORMIX »
Muchas Gracias
I'm pleased to announce update 1 build of MiniGUI 23.10.
I've uploaded the updated setup for Borland C++ 5.8.2 (32-bit) at
and an alternative link to the zip archive:
https://hmgextended.com/files/CONTRIB/h ... -setup.zip
Upgrading to this update is optional.
[MiniGUI Team]
Hi Friends,
for the MinGW C-compiler:
Minigui Ex Package (build date: 13.11.2023)
Components versions:
Harbour MiniGUI Extended Edition 23.10 (Update 1)
Harbour 3.2.0dev (r2311121540)
Harbour Make (hbmk2) 3.2.0dev (r2023-11-12 15:40)
gcc version 13.2.0 (MinGW-W64 i686-msvcrt-posix-dwarf, built by Brecht Sanders)
Minigui Ex 64 Package (build date: 13.11.2023)
gcc version 13.2.0 (MinGW-W64 x86_64-msvcrt-posix-seh, built by Brecht Sanders)
(using the example of “MySql Client”), and they are available to all donors.
Thanks for your attention. :)
Thanks !
