I have a big problem
martingz
Post by martingz »
I have a problem, a program that had been working efficiently for more than 5 years, after a Windows update it does not add all the records, it is not always, something like this happened to someone, this problem started in this month of October
There are thousands of transactions a day and it has never failed.
ASESORMIX
Re: I have a big problem
Post by ASESORMIX »
usa la funcion dbcommitall() luego de replace...
martingz
Post by martingz »
Asesormix en si la uso, y nunca fallaba, hasta principios de este mes de octubre, puse un do events despues de dbcommitall() y en ocasiones llegaban 2 o 3 registros del mismo recibo
Por el problema pienso que es una actualizacion de windows pero hay 2 que no me deja quitar , el peor problema es que tenemos 1o cajas de cobro
que estan fallando de esa manera
saludos
Martingz,
- log ALL your appends/updates/deletes into TXT files
- modify DBF with 2 fields: ts_insert and ts_update char(26) and fill with timestamp (date() + time()) when inserted or updated
OR more drastically:
migrate to MySQL database
serge_girard wrote: Fri Oct 27, 2023 7:19 am Martingz,
You may consider using the SQLRDD library as a first step when migrating to a MySQL server:
viewtopic.php?f=15&t=7472
:arrow:
martingz
Post by martingz »
Thank you all for your comments
Serge, we are moving all our systems to MaridDB but it is a huge job, we are only 3 programmers. we have about 60% of the work finished
It is almost certain that there is an error in a Windows update.
"For developers, affected connections may receive one or more records in a single input buffer, followed by a partial record less than 5 bytes in size,"
i don´t "think" that there was a Windows "Apps" Update which make Problem ...
have not hear about other People having Problem
but there was Windows Defender Update which often make Problem when "scan" Files
Tip : disable Folder where you have your DBF to "scan" by Windows Defender
you can use Powershell "as Administrator", on every Workstation, and type
Add-MpPreference -ExclusionPath "Your_Folder_to_Exclude"
MariaDB is very fine! Indeed huge job!
franco
Post by franco »
I had similar problem. I had taken out some of my dbcommits in my invoicing program. Forgot why, and had to add back.
I then found I had a problem with table names. I have have 2 tables with same starting names.
INV for inventory table . INVOICE for invoice table.
When I was deleting an item. My code was delete for len(alltrim(invoice->inv)) = 0. It was deleting when it wasn`t 0.
I had to change the = to == and problem stopped. So changed all my = to == .
This didn't use to happen but just in last year or so.
Also I close all tables when finished any edits and open when starting. I think this also commits data.
I don`t open a database with all tables in it and the just select the table when using.
For when invoicing I open (invoice, inv_item, customer, inventory, accrec, daysales) and close them when finished.
I still have not been able to get any sql to work.
Franco
All The Best,
Franco
Canada
martingz
Post by martingz »
Auge_ohr,
We do not use Windows Defender, the program was working very well until this month of October and according to Microsoft documentation there are problems in sending packages, it is not all the devices we have almost 200 online, only the paid devices, which have thousands of daily transactions
this is the code
for y = 1 to main.grid_2.Itemcount
aValues:=main.Grid_2.Item(y)
if !empty(aValues[1])
select dia_pag
append blank
dia_pag->cve_cpto:=aValues[1]
dia_pag->ruta:=varrut
dia_pag->folio:=varfol
dia_pag->fecha_pag:=main.text_18.value
dia_pag->pago_act:=aValues[3]
dia_pag->fte_pago:=mftepago
dia_pag->cve_captur:=main.text_1.value
dia_pag->recibo:=main.text_12.value
dia_pag->hora:=time()
dia_pag->timbrado:='1'
dia_pag->(DBCommit())
dia_pag->(dbunlock())
next
dia_pag->(DBCommitall())
dia_pag->(dbunlockall())
nexxt
