HMG for create PHP code
dragancesu
DBs Used: DBF, MySQL, Oracle
Post by dragancesu »
I need and create little creator for php with crud functions ( create, read, update, delete )
In ZIP is one sql for create table
Note: field type for php form is different than dbf
C - character
N - numeric
E - email (field is character)
P - password (field is character)
R - radio (field is character)
program need field ID INT NOT NULL AUTO_INCREMENT as PRIMARY KEY
Please look and comment, but I am beginer in this
I think that you know MySQL, Sql, Html and PHP
first step is build hmgphp.hbp
hmgphp.zip
(23.65 KiB) Downloaded 342 times
Re: HMG for create PHP code
Dragan,
Is it the meaning to to generate PHP file?
dragancesu
Yes, of course. But no one.
On DB connect->connect create config.php
On Table->Edit click on Build create index, create, update and delete php
Wow! That is so great. It will make the users to access data from anywhere in the world. Thanks a lot!
